Page 1 of 1
Question regarding Point Grey Chameleon3 with IMX265 mono
Posted: Mon May 16, 2016 3:14 am
by Rysmdoc
Hi, I recently purchased this camera and used it for the transit. I am happy with it but I noticed that changing the gamma in Firecapture does nothing to the image. I then tried to change the gamma in FlyCap2 and I am unable to. The gamma slider immediately jumps back to its original setting. Am I missing something? is this normal behavior for this camera?
Carlos
Re: Question regarding Point Grey Chameleon3 with IMX265 mon
Posted: Mon May 16, 2016 6:18 am
by pstew
I have just got a Chameleon3 (IMX264) and have noticed the same thing. It will work in FlyCap2 if you change the video mode to mono instead of raw.
Gamma works fine in Genika, I suspect FC is setting the mode to raw instead of mono.
I have seen your post in the FC forum and have added what I know, hopefully Torsten will get it sorted.
Posted: Mon May 16, 2016 7:04 am
by robert
I have a ch3 and am used to Firecapture which I like. I found the gamma control does not work in any version beyond 2.3 so I use that and have no problems. Dump 2.4 etc and go back to 2.3 is one solution
Robert
Posted: Mon May 16, 2016 8:03 am
by marktownley
robert wrote:I have a ch3 and am used to Firecapture which I like. I found the gamma control does not work in any version beyond 2.3 so I use that and have no problems. Dump 2.4 etc and go back to 2.3 is one solution
Robert
That's what I do!
Posted: Mon May 16, 2016 8:30 am
by robert
It works for me!
Posted: Mon May 16, 2016 11:25 am
by Rysmdoc
Great! Thanks all I appreciate the advice. I'm going to download 2.3 and give it a go.
Posted: Sat May 21, 2016 1:46 am
by pstew
Torsten has modified the DLL's to allow FC to run in Mono mode instead of raw. Gamma will now work in FC 2.5 with a slight drop in FPS.
The DLL's can be downloaded here
https://groups.yahoo.com/neo/groups/firecapture/files
