New Skywatcher Solarquest mount
Has thanked: 629 times
Been thanked: 728 times
Re: New Skywatcher Solarquest mount
Post by DeepSolar64 » Sat Feb 29, 2020 7:07 pm
I have thought about getting the Orion Solar Starseeker mount. It looks similar.
https://optcorp.com/products/orion-sola ... th-mount-1
Has thanked: 1523 times
Been thanked: 613 times
Post by marktownley » Sat Feb 29, 2020 8:29 pm
Looks to be the same thing just badged different...
Post by DeepSolar64 » Thu Mar 19, 2020 6:22 am
All,
I plan to get a new mount/tripod assembly in the near future. I am considering the Orion Solar Starseeker mount for solar and the regular Orion Starseeker GoTo Or Celestron NextStar mount for nighttime use. All are under 500 dollars US. Does anyone make one like these that will track all three lunar, solar and sidereal? On many nighttime mounts like the NextStar three objects have to be located and entered to align the scope. That's not possible during the day. The solar mounts do this by locking onto the sun but a multi-use GoTo mount would have not enough objects to go through the setup process in the daytime. Unless maybe it is GPS equipped and can use that standalone. I would like a tracking mount for my Coronado SolarMax II DS and Orion 70mm White Light Solarscope. And my nighttime use Astro-Tech 72EDII refractor. Must I buy two different mounts?
The SkyWatcher SolarQuest looks very similar to the Orion StarSeeker mount. They may indeed be the same.
JochenM
Has thanked: 109 times
Been thanked: 427 times
Post by JochenM » Thu Mar 19, 2020 7:47 am
Hi James
Nowadays, most mounts have a solar tracking option within their software/firmware. I have a few mounts, but my process (for solar work) is pretty much the same for every single one:
- Put down the mount and make sure it's roughly pointing north (I'm not very precise on this, just a rough visual estimate) and set the latitude on the scale/dial (whatever you call that) if it's an eq one.
- Skip any sort of alignment procedure in its totality.
- Tell the mount to slew to where it thinks the sun is (this will be a bit off usually). Correct it by manually slewing until I have the sun centered in my eyepiece/camera and confirm.
- Enable solar tracking in the firmware.
- All done.
All my images at: https://flickr.com/photos/jochenmaes/
My photography site: http://jochenmaes.com/
Post by DeepSolar64 » Thu Mar 19, 2020 3:28 pm
Thanks Jochen. Which mounts do you have? I don't rule out an equatorial mount but am eyeing altaz for simplicity.
JochenM
Post by JochenM » Thu Mar 19, 2020 4:06 pm
I have the following ones:
- Bresser EQ mount. Forgot what the thing's called exactly.
- Skywatcher AZ-EQ6
- Skywatcher AZ-GTi
- Skywatcher SolarQuest
But for solar work only, an alt-az is usually more than sufficient (assuming it's stable and can carry the weight etc obviously).
Post by DeepSolar64 » Thu Mar 19, 2020 4:10 pm
I have been looking at the SkyWatcher AZ-GTi. Does it have both solar and sidereal capability?
JochenM
Post by JochenM » Thu Mar 19, 2020 4:22 pm
It has sidereal, solar and lunar tracking.
Post by DeepSolar64 » Thu Mar 19, 2020 4:25 pm
Awesome!!
Does it work well for you on all three? Is it easy to align and set up?
JochenM
Post by JochenM » Thu Mar 19, 2020 4:50 pm
I've only ever used it for solar/lunar work.
I always just slew to the sun/moon manually, enable the relevant tracking mode and do my thing, so I can't really say much about the alignment process. Once it's on target, it tracks very well for longer periods of time though.
Post by marktownley » Thu Mar 19, 2020 7:38 pm
Yes, it has solar and sidereal capability.
I have one. Personally, I don't get on with it. I bought it because I wanted something that would cater for the couple of times a year when I take a small scope to a dark sky, but for the rest of the time solar.
I don't like using my phone as the hand controller for it, so I bought the skywatcher handset for it. You can't do solar with the handset for whatever reason. I've just found myself swearing at it and packing it away when I get it out. I'm just going to get the solarquest version instead.
Clearly others might not share my experience, I get that.
Post by marktownley » Thu Mar 19, 2020 7:39 pm
Maybe I need to try this!
Martin_S
Has thanked: 41 times
Been thanked: 149 times
Post by Martin_S » Fri Mar 20, 2020 3:27 am
Mark , I too have the AZGTi, I might as well use it as a doorstop, mainly due to the absence of an ST4 guide port. If someone ever comes up with an ST4
interface that could plug into the handset port, then that would be a real game changer. We could then use our solar auto guiders and have a great portable mount.
The AZGTi works with pulse guiding with PHD2. I have tried Lusol Guide with pulse guiding on the AZGTi and could not get it to work.
Martin
H - alpha setup
Lunt LS60THa Tilt-Tuned Solar Telescope, LS50FHa solar filter front-mounted Double stack etalon. 2 x Barlow
Remote etalon and focusing control's ASI290mm Camera
White Light setup
Skywatcher ED72 ,ED100, Homemade solar wedge, IR cut filter, Solar Continuum filter.
Mounts
Skywatcher HEQ5 Pro Mount ..
Darkside setup
Skywatcher ED72 ,ED100, GSO RC6 ,Celestron Nexstar 6SE.
Post by DeepSolar64 » Fri Mar 20, 2020 4:41 am
Thanks Jochen, Mark and Martin. I would use it mainly for visual so my demands would probably be less. But is would still need to be easy to use and have decent tracking and GoTo capability. I have 4 scopes to use with it, the Orion ST90 being the largest. But it is actually a tad bit lighter than my double-stacked SolarMax II 60.
Martin_S
Post by Martin_S » Fri Mar 20, 2020 5:09 am
James , just take note the Solarquest and AZGTi have a payload of 5kg max. The supplied tripod with a 5kg load is top heavy. I would be wary of mounting an expensive telescope on this tripod.
I made a heavy duty pier mount for mine.
Martin
H - alpha setup
White Light setup
Mounts
Darkside setup
Post by DeepSolar64 » Sat Mar 21, 2020 5:41 am
Thank you for the advice Martin. Your home-built pier does look very stable.
