"Coated" Lunt BG38 Blue filter?????
Has thanked: 4 times
Been thanked: 29 times
Post by Merlin66 » Wed May 06, 2020 1:28 am
https://luntsolarsystems.com/shop/solar ... g-filters/
I see there are reports, on SGL, that the replacement Lunt "Blue" filters for the BF assembly are "coated" for additional protection..
I'm unable to confirm.
Does anyone have some confirmation details on this filter's current construction?????
Has thanked: 1586 times
Been thanked: 628 times
Re: "Coated" Lunt BG38 Blue filter?????
Post by marktownley » Wed May 06, 2020 5:31 am
Doesn't look coated in the Lunt pic in the link. Looks like normal BG38 to me. What has SGL got to say?
Post by Merlin66 » Wed May 06, 2020 6:13 am
In a recent post he says:
Lunt were able to tell me that the blue glass is a UV Cut filter.
The newest version has a coating to inhibit this build up.
They also confirmed it was OK to try and clean the old BG filter and suggested CLR.
I'm following it up with "Anthony" the member on SGL.....
Has thanked: 659 times
Been thanked: 775 times
Post by DeepSolar64 » Wed May 06, 2020 5:53 pm
CLR? Awesome!!! You can clean them!
Post by marktownley » Wed May 06, 2020 7:33 pm
Yeah, it's all based on soda glass, so it just effectively oxidizes on the surface. Straightforward to remove.
Post by DeepSolar64 » Thu May 07, 2020 5:38 pm
That's really good to know. This applies to both Lunt and Coronado BFs?
Post by Merlin66 » Fri May 08, 2020 8:14 am
No, the Coronado ITF is a completely different design.
If it fails, the Maier Photonics replacement is a drop in replacement.
Post by DeepSolar64 » Mon May 11, 2020 5:43 pm
The Coronado BFs cannot be cleaned off if they oxidize?
Post by marktownley » Mon May 11, 2020 6:32 pm
No. The Coronado ITF is a laminated filter, the oxidation occurs between the layers. These are bonded with an epoxy and cant be separated.
Post by DeepSolar64 » Mon May 11, 2020 6:36 pm
Well Lunt has it on Coronado over that. Do you have a link for Maier Photonics if I ever need it?
Post by marktownley » Mon May 11, 2020 6:40 pm
Post by DeepSolar64 » Tue May 12, 2020 4:48 pm
Thank you for the link, Mark. I will save it for sure.
