new refractor
alessbonsai
Has thanked: 5 times
new refractor
Post by alessbonsai » Sun May 17, 2020 4:19 pm
Hello friends
Do you recommend an F11 +/- refractor, to be used for both the sun and the planets.
I had thought of the Tecnosky 102/1100 or TS, both the ED and normal version.
Unfortunately I have space problems and I can't go overboard with the tube size.
I'd use it on an Avalon Muno mount
I also have a Coronado PST and in the future a daystar.
And I should use everything for both photography and visual.
Alessandro
Danke im voraus
Has thanked: 1586 times
Been thanked: 628 times
Re: new refractor
Post by marktownley » Sun May 17, 2020 6:53 pm
Yes, it's a good scope :) Welcome to the forum.
Has thanked: 659 times
Been thanked: 775 times
Re: new refractor
Post by DeepSolar64 » Mon May 18, 2020 1:16 am
Longer focal length refractors are usually very good on visual views of the sun, moon and planets. It's recommended with an achromat since the longer FL reduces spurious color. You can go shorter with ED and apochromatic scopes since their better glass and multiple lens elements control chromatic aberration much better.
Shorter FL ED apochromats take up less space than classic long FL achromat designs.
Welcome to SolarChat
alessbonsai
Re: new refractor
Post by alessbonsai » Fri May 22, 2020 7:16 pm
Thanks for the answers, I think I will take a TS 102/1100 ED, if you have other ideas shot
Astrograph
Been thanked: 36 times
Re: new refractor
Post by Astrograph » Sat Jun 06, 2020 4:28 pm
The Tecnosky and TS 102/1100 are the same scope made by United Optics. There is no ED version as it is an Achromat. It is quite a long telescope and would not be suitable for an M Uno.
If you are looking to stock to a fairly low budget then I would suggest the Tecnosky or TS 102/714 ED Doublet. This is F7. It is more than double the cost (I sell it for £899) but it has a better focuser, can be used with rear mounted solar filters, is far better corrected and would work on an M Uno as it is much shorter.
