LS60MT VS LS60THa.
Taipan
Has thanked: 1 time
Been thanked: 39 times
LS60MT VS LS60THa.
Post by Taipan »
My question is witch of those should i bye? :)
Is the MT the new version of Lunts 60mm scope? Better etalon in that one?
Only gonna use it fore sun Ha so the fact that i can use the MT as at night scope is not an issue.
Lunt LS60MT/B600PT SS. Neptune-M (IMX178), Apollo-M Mini
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: LS60MT VS LS60THa.
Post by EGRAY_OBSERVATORY »
My honest opinion, after having owned and well used a LS60THaFT/B1200 as the LUNT 60mm Hydrogen-Alpha/FeatherTouch/B1200-Blocking-Filter
and a LS60TCak/B1200/FT as the LUNT 60mm Calcium-K/BF1200/FeatherTouch SolarScope both since 2010, is that although I can see the purposes of a modular telescope for other than Solar purposes, as far as a pressure-tuning system is concerned :-
the more that is added to a telescope, the more is likely to/ and does go wrong. "Murphy's Law" states that.
I have had no such problems, where I know others have had, even though in some cases those problems can be resolved quite easily/cheaply and often with the excellent service from Lunt too..
In fact, I have three scopes on the very reliable and able SKYWATCHER AZ-EQ6GT Alt-Az and EQ Go-To Mount - with three cameras plus all the cables etc., so a decent and capable mount is a better investment than having a pressure-tuning/modular system and more importantly, I very rarely have to adjust the focusing and Etalon-tuning of my systems in the observatory, unless a specific change is required - such as adding Barlows etc...
Ultimately as you can see from the specs of my own two scopes, getting the FeatherTouch focuser is a must for its' reliability and ease of using in fine-focusing. Also for the 60mm versions the minimum Blocking Filter should be the BF1200 for both visual and imaging purposes and that arrangement has well proven itself - when looking back over the archives of SolarChat.
So as you say about only using for Solar purposes, you have more or less answered your own question and I wish you well with your decisions.
Regards
EGRAY OBSERVATORY
S.E.England
Taipan
Has thanked: 1 time
Post by Taipan »
And the small difference 0,7Å-0,65Å between the two models are nothing to worry about??
Taipan
Has thanked: 1 time
Post by Taipan »
Oh, another question.. Is it possible to use the 50mm DS filter from my LS50 on the 60mm modell??
EGRAY_OBSERVATORY
I can't vouch definitely for the A - differences, as if I want to, I double stack my Ha 60mm with a 60mm DS which obviously makes the contrast much- better for Solar-surface detail, albeit with the loss of prominence detail. Of course a 0.5A difference is very nice...
I generally for imaging prefer to leave the DS off, so make the best of the surface-detail by adjusting in the post-processing stage, as the DS's are quite heavy and can easily be dropped when removing/fitting, so my one has large rubber-bands around it to allow for a better-grip... (old age)...
Indeed, yes the LS-60mm Ha scope can use the 50mm DS unit, which of course can/will be ordered separately and I would recommend getting the scope first and decide on the additional DS acquisition - if desired. The 60 DS is of course much more expensive - so the decision is yours... !!!
CLEAR SKIES
Taipan
Has thanked: 1 time
Post by Taipan »
EGRAY_OBSERVATORY wrote: Sun May 09, 2021 1:06 pm I can't vouch definitely for the A - differences, as if I want to, I double stack my Ha 60mm with a 60mm DS which obviously makes the contrast much- better for Solar-surface detail, albeit with the loss of prominence detail. Of course a 0.5A difference is very nice...
CLEAR SKIES
Ok. I allredy have the LS50 with the DS-filter. Was thinking of sell my LS50 and keep the DS-filter if it will work with the LS 60. Then bye a LS60 with the 1200 blockfilter..
It's this filter i already have.
https://luntsolarsystems.com/shop/solar ... ck-filter/
EGRAY_OBSERVATORY
That's excellent news and should save you much money tooooo...
Cheers
Taipan
Has thanked: 1 time
Post by Taipan »
So, is there some kind of adaptor to fit the 50mm to the 60??
EGRAY_OBSERVATORY
Sorry for the delay in replying, as have just been on the telephone to Mauritius for the last three hours - OOOh AAAh !!
I believe that the 50mm DS you have will also fit the 60mm scope, but a confirmation from Lunt, where you should give the exact product-code of yours - will confirm that, as I already know that 50mm aperture DS have been/are being supplied for 60mm scopes. Just slightly reduced open-end aperture.
So talk to Lunt or a Lunt agent for confirmation.
Best wishes
Taipan
Has thanked: 1 time
Post by Taipan »
EGRAY_OBSERVATORY wrote: Sun May 09, 2021 5:06 pm Sorry for the delay in replying, as have just been on the telephone to Mauritius for the last three hours - OOOh AAAh !!
Best wishes
Ok. Then you almost fooled me:) Pretty sure the 50mm filter you are talking about isn't the same as for the LS50..
Guess i have to try selling the filter with the scope then..
EGRAY_OBSERVATORY
I did say earlier, that if you decide to use a DS for the 60mm then order it separately (and later on) and if required that your existing DS does-not fit the new 60mm, then check this out then and talk to LUNT for any further advice of whether a 50mm aperture (not the fitting ring to the scope) will be you next option, but remember there is a considerable price-difference.
I'm down for two-hours from 1830BST/1730z
Cheers
Has thanked: 20738 times
Been thanked: 10437 times
You can get an adapter from Precise Parts...
