Refractor question
Has thanked: 9292 times
Been thanked: 6127 times
Refractor question
Post by ffellah »
Hello all: does it make any sense to "upgrade" from a 152 mm achromatic refractor to a 130mm triple APO refractor at approximately double the cost ? It would mean sacrificing 1" of aperture for a sharper image, I guess.
Interested in hearing your opinions...
Thank you,
Has thanked: 20738 times
Been thanked: 10436 times
Re: Refractor question
Hi Franco.
For solar, no, not at all. Quite the opposite.
If you are looking for decent night time yes the apo.
Post by ffellah »
Thanks a lot, Mark, I am glad I asked.
Has thanked: 17807 times
Been thanked: 16948 times
Post by DeepSolar64 »
Franco,
I don't think it would be worth it unless you choose to use it for nighttime as well. The narrow band filters used in solar usually remove the chromatic aberration of an achromat. If the lens is of good quality I would not sacrifice the aperture of the larger achromat for the smaller APO unless you choose to use the scope on objects outside of the Sun.
I am weighing the Celestron C6-R achromat against the Astro-Tech AT130EDT triplet apo and have came to the same conclusions.
Post by ffellah »
Thank you, James, I was thinking of the same Astro Tech 130.
ffellah wrote: Fri Jul 09, 2021 10:43 am Thank you, James, I was thinking of the same Astro Tech 130.
They make nice instruments, Franco. I have their little AT72EDII and it has practically no chromatic abberation. It's a doublet with a lanthanum element mated to an Ohara FPL53 element. Both ED glasses.
SharpStar would be another good option for an affordable ED/APO. They are really nice too.
But if it's just for solar a good achromat is more affordable.
Post by ffellah »
Thank you James
Glad to help, Franco. Good luck with your choice.
