Tuesday Sun 12th Jan. 2021
- Has thanked: 8559 times
- Been thanked: 8297 times
A beautiful blue sky morning and plenty of sunshine, although the seeing conditions were very marginal for close-up views. Nevertheless I had a go with the 150 mm mod on a couple of proms and a magnetically disturbed region. The FD in Ca II K was straightforward enough on a 72mm scope fitted with a B1800 Lunt module and a couple of additional filters (Baader K-Line and Omega).
First up are the Ca II K disks in mono and colour.
20210112_CaK_FD by Stuart Green, on Flickr
20210112_CaK_FD_colour by Stuart Green, on Flickr
These were the two main proms on show in Ha. This is where the seeing conditions made it very difficult to obtain good, stable, views.
20210112_Prom1 by Stuart Green, on Flickr
20210112_Prom2 by Stuart Green, on Flickr
Finally, a close view of the magnetically disturbed region. Again, the seeing conditions really limited my ability to get a nice sharp image, so it looks a bit fuzzy. You have to get what you can
20210112_Ha by Stuart Green, on Flickr
Thanks for looking.
Thanks for looking.
- Oh, I get it now!
- Been thanked: 71 times
Re: Tuesday Sun 12th Jan. 2021
Even with no perfect conditions, the photos are very good Stu! I like very much the close up one.
Joseph
Joseph
Hi Stu, glad you got some clear-ish skies today after all the heavy rain that swept across the UK.
Excellent captures and the proms are well-good for a quiet Sun
Those are very good images, Stu. Nothing but clouds here today. Thanks for the view.
Phil
Phil
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Thanks for posting Stu, lovely image's.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20828 times
- Been thanked: 10502 times
Good results Stu! Glad you got some sunshine. Using the 150 this time of year is brave but they came out surprisingly well.
Many thanks, everyone. Comments are always very much appreciated.
- Been thanked: 4434 times
Well done Stuart
The 150mm scope still produced good, detailed images !!!
- Has thanked: 3321 times
- Been thanked: 1907 times
- Has thanked: 9327 times
- Been thanked: 6163 times
A beautiful set of images notwithstanding the weather conditions, Stu.
- Been thanked: 8907 times
Interesting to see the intense patches of plage in the CaK, these could be active regions which will form over the next couple of weeks, hopefully big by their next pass round
The close ups of the proms are exceptional
Very busy couple of days at work here
