Hello everyone,
Just wondering what settings folks use for the ImPPG brightness normalization setting for WL, Ha and CaK imaging. Or do you not use this feature at all?
Jordan
ImPPG Brightness Normalization
- Jordan Konisky
- Has thanked: 386 times
- Been thanked: 270 times
Jordan -
Lunt CaK B1800 Filter Module
Lunt White Light Solar Wedge
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 757 times
Re: ImPPG Brightness Normalization
Hi Jordan,
I've added it to aid batch processing time lapses where the image brightness was slowly varying during capture, e.g. due to passing clouds, or just a sunset/sunrise as in this long lunar animation. (If you don't use batch processing, you can achieve the same normalization effect simply via tone curve adjustment.)
If you use it, I recommend setting the normalization range to 10%-90% or 20%-80%, as any subsequent sharpening usually expands the histogram.
Note that it won't work too well if the target's intrinsic brightness also changes, e.g. if a flare starts in an AR.
- Jordan Konisky
Thank you. Very helpful.
Jordan
Jordan
Jordan -
