Friday Sun 31st July '20
- Has thanked: 8543 times
- Been thanked: 8274 times
Hi all,
A hot day here and the morning started with a boiling Sun. The seeing conditions were just about good enough to capture some hi-res images in Ha and Ca II K.
Hydrogen alpha FD imaged with a Lunt 60 and the Hi-res images were captured with a 150mm/DS Lunt 35 mod. My RCT didn't cut it with the conditions.
Calcium II K images were captured with a Lunt B1800 for the FDs using a 72 mm f6 refractor and the hi-res images were captured with a 125 mm f7.8 refractor and Lunt B600.
20200731_Ha_FD_Mono by Stuart Green, on Flickr
20200731_Ha_FD_colour by Stuart Green, on Flickr
With Prom...
20200731_Ha_FD_Prom_colour by Stuart Green, on Flickr
20200731_Ha_AR2767_Mono by Stuart Green, on Flickr
20200731_Ha_AR2767_colour by Stuart Green, on Flickr
20200731_Ha_AR2768_Mono by Stuart Green, on Flickr
20200731_Ha_AR2768_colour by Stuart Green, on Flickr
20200731_CaK_FD_Mono by Stuart Green, on Flickr
20200731_CaK_FD_colour by Stuart Green, on Flickr
20200731_CaK_AR2767_Mono by Stuart Green, on Flickr
20200731_CaK_AR2767_colour by Stuart Green, on Flickr
20200731_CaK_AR2768_Mono by Stuart Green, on Flickr
20200731_CaK_AR2768_Colour by Stuart Green, on Flickr
Thanks for looking.
With Prom...
Thanks for looking.
- Has thanked: 141 times
- Been thanked: 240 times
Re: Friday Sun 31st July '20
Gorgeous
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
- Has thanked: 17829 times
- Been thanked: 16971 times
The emerging plage to a third AR is seen behind AR12768 in the CaK images! Big thumbs up Stu!
Hi Stu,
Nice images, especially in CaK at a high res.
BTW Why don't you use a big 10" cannon?
- Has thanked: 17970 times
- Been thanked: 8903 times
Tremendous set Stuart, especially the CaK I too had a great time but stuck with the TEC140. I managed to test the C11 afterwards to try and iron out a few problems but the seeing through that was terrible but it didn't matter for my testing.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Been thanked: 4900 times
Many thanks, everyone.
Hi Valery,
I started with the RCT, but the conditions just didn’t cooperate. I couldn’t freeze the effects of my local atmospheric seeing conditions well enough to give anything worth keeping.
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
- Has thanked: 20778 times
- Been thanked: 10454 times
Great run of images Stu, a well timed day off!
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Great images, as usual, with lot of contrast and details
- Been thanked: 4971 times
Stu:
Super session and images, clean, even and crisp.
Many thanks, Jochen, Mark, Raf and Eric.
- Been thanked: 4419 times
Superb series of image Stu...well done
- Has thanked: 1187 times
- Been thanked: 1382 times
