I am using a 6mp PGR Grasshopper3 and it often will overheat and shut down. I live in norther California and the temperatures can get into the high 90s. Of course this camera was probably not designed to work in the direct sunlight during the California summer heat. I contacted Point Grey, but they told me I was on my own with this. Has anyone else encountered this? What solutions can you offer?
www.randallbenton.com
[email protected]
2321 Goldorado Trail
El Dorado, CA 95623
530 642-2912
Camera overheating
- Has thanked: 20435 times
- Been thanked: 10243 times
Re: Camera overheating
Hmmm, not sure what to suggest, maybe make a sun shield for it to keep the direct sunlight off it?
- Been thanked: 4904 times
- Been thanked: 1735 times
Hi Randall
I think on very hot days wrapping it in aluminum foil might do more harm than good since the internally generated heat will be reflected back into the camera by the inner face of the foil and cause heat build up that way. Maybe a very cheap shield could be made that fits over the snout to keep the camera in shadow while allowing air to circulate around the camera.
Lou
Lou
- Been thanked: 2713 times
You may try installing a passive heat dissipator. I've got one on my camera.
- Been thanked: 34 times
Christian Viladrich, what does your passive heat dissipation look like?
Randall Benton
Randall Benton
I've got that one on my camera :
http://www.selectronic.fr/radiateur-pour-to3-ml41.html
I am not sure of the actual name in English :-(
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 753 times
I also suggest a sunshield (if in your setup the camera is not completely in telescope's shadow) and radiator(s), e.g. search for "RAM aluminium heatsink" (computer stores). If it's not enough, there are tiny (e.g. 40 mm) fans available too.
- Bob Yoesle
- Has thanked: 540 times
- Been thanked: 807 times
