Granulation on 25th Feb
- robert
- Has thanked: 4 times
- Been thanked: 1286 times
Good seeing and totally clear sky with a low sun. I have been trying to do white light granulation animation for a while and this is probably my best attempt yet, certainly the best conditions. I used a Skywatcher 200mm Newtonian with Baader ND3.8 astrosolar film, UV/IR cut, Baader continuum, Televue x5, guided with a Hinode solar guider. (effective FL 5000mm)
The file is 8.5minutes at 15 second cadence and unfortunately is 57Mb so will be slow to load before it runs. Hope you like it. I need to work out how to do it bigger and better! The sun being higher in the sky is my first thought
Robert
(open in a new tab for full size)
Robert
- Has thanked: 9385 times
- Been thanked: 6199 times
Re: Granulation on 25th Feb
It took a while to load but a very nice animation, Robert !
Better when opened up in a separate window....what are those black cells that seem to be reabsorbed ?
- Has thanked: 8588 times
- Been thanked: 8324 times
Nice work, Robert.
- pedro
- Has thanked: 14 times
- Been thanked: 6749 times
- Has thanked: 18105 times
- Been thanked: 8939 times
Wow! superb clarity and the granulation cells are nice and angular, this is a beautiful piece of work Robert, something I am desperate to try this year with the C11 nice to see a few pores as well
- robert
Thanks for looking and commenting, Franco, Stu, Pedro and Alexandra.
I did an SSM record and marked the time in green (1 arc sec and below, 10.47-10.55UTC). Early in the morning and low seems better than later on with a higher sun but the wind was rising too on this day. I think better scale on the granules is what I would like, so your C11 should do that, Alexandra. I see from Flickr you already have an ADM saddle clamp (my not so useful suggestion) so good luck with the C11 lifting arrangements. I am sure you can sort something, straps handles, steps... whatever. Good luck. I may try my low contrast C925 if I ever get such good seeing again. Not so sure about that
- robert
The tonal difference between the edges of the granulation cells and the centres are directly related to the temperature. The hot plasma rises in the centre and cools becoming darker as it falls around the perimeter of the cell. So I have read! I think the darker cells must just be at a lower temperature so it shows how active the surface is. This is just 8.5 minutes and the temperature and shape of the granules are all over the place during that short time.
Robert
- Been thanked: 5016 times
Robert:
Very good HR animation.
BTW, the granules are +- 1 arc second in size.
The SSM shows a very good seeing.
- robert
Thanks Eric, SSM is fairly new for me, I think I like using it!
- Has thanked: 20940 times
- Been thanked: 10587 times
This is brilliant Robert. I want to try some granulation later this year with the HaT, I should get a very similar image scale to what you are getting there. Your seeing looked pretty good too looking at the graph from the SSM.
- Has thanked: 1 time
- Been thanked: 2725 times
This is very well made. Congratulations !
- Christopher
- Has thanked: 33 times
- Been thanked: 34 times
Very cool Robert!
Christopher
- robert
Thank you Mark, Christian and Christopher. I had a lucky chance with the seeing.
