The Sun on May 5 2018 as seen with 280mm aperture.
Post by Valery » Mon May 07, 2018 4:14 am
This morning was a calm with good seeing. I caprtured the sun in CaK and H-a.
The image in CaK was taken first when the seeing didn't start to degrade with the sun going higher in the sky.
AR12708 in CaK at 0,087"/pixel
AR12708 in H-a with a mini-flare
some activity at the eastern limb
Derek Klepp
Re: The Sun on May 5 2018 as seen with 280mm aperture.
Post by Derek Klepp » Mon May 07, 2018 6:12 am
Excellent set Valery.
Post by ffellah » Mon May 07, 2018 10:46 am
Excellent resolution, Valery. AR2708 is so tiny....
Post by Montana » Mon May 07, 2018 12:55 pm
Wow!! what a set!! :bow :bow :bow
Post by Valery » Tue May 08, 2018 3:21 pm
Yes, Franco, the resolution here at 393nm is about as a 465mm telescope has at H-a 656nm.
A par with 300mm telescope at 430nm G-band.
As soon as my SCT has obtained a corrective optics for 393nm, the images at this wave length became much better and often have a diffraction limited resolution.
eroel
Post by eroel » Tue May 08, 2018 4:10 pm
Valery:
Super shots.
Post by Valery » Thu May 10, 2018 2:11 pm
Thanks to all you.
Post by marktownley » Sun May 13, 2018 8:10 am
These are brilliant Valery!
Post by Valery » Mon May 14, 2018 11:04 am
Thank you, Pedro and Mark.
I hope to make more hig res solar photos in the CaK line.
Post by marktownley » Mon May 14, 2018 1:38 pm
Are you using the SAFIX with the CaK shots Valery?
Post by Valery » Mon May 14, 2018 2:12 pm
This time I didn't use the SAFIX. Another corrective lens has been used.
Valery.
allhoest
Post by allhoest » Fri May 18, 2018 6:34 pm
Once again, great shots!
CS
Alex
Post by Carbon60 » Sat May 19, 2018 5:36 am
Fabulous, Valery. Wonderful images.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Post by Valery » Sat May 26, 2018 3:27 pm
Thank you, Alex and Stu.
allhoest
Post by allhoest » Sun May 27, 2018 9:14 am
Great shot in CaK.
I look forward for your next posts with the new corrective lens.
CS
Alex.
Post by Valery » Sun May 27, 2018 12:18 pm
Great shot in CaK.
CS
Alex.
You can see it here: https://www.cloudynights.com/topic/6181 ... try8578847
Unfortunately the seeing was not good at all.
