Hi:
Started clouded, then hazy and later rained, but There were some clear spots once in a while, so I stayed at the home observatory just trying to catch the brief periods of shinning sun.
Used the usual Solarmax 90-DS for Ha FD shots, the 102mm f/9 Meade refractor with the CaK mod, with a 0.5X reducer for FD, then at native focal length and also with a 3X Barlow. Also used the 102mm f/7 Stellarvue with a full aperture Daystar ERF (yellow), a 4X Baader Telecentric and an old Daystar T-Scanner. The camera for all shots was the SKYnyx 2-2.
Thanks for looking,
Sol from the 14th of July 2018.
- Been thanked: 4904 times
- Has thanked: 8420 times
- Been thanked: 8169 times
Re: Sol from the 14th of July 2018.
Nice images, Eric. Looks like you had a productive session.
- Has thanked: 9149 times
- Been thanked: 6029 times
- Been thanked: 4342 times
Excellent series of images Eric
- Has thanked: 20448 times
- Been thanked: 10250 times
An excellent set Eric, I like the CaK closeup!
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
Hi Eric
A very patient session - the CaK's & proms look excellent - thanks for the views.
- Been thanked: 8794 times
Wow! I do marvel at your CaK shots I always have a problem that they are blurred, how do you get them so crisp?
Alexandra, Stu, Franco, Brian, Mark and Matt, thanks for looking.
Alexandra, I record them with low gamma and high gain.
Best wishes to all,
Best wishes to all,
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Beautiful shots, Eric.
The Ca full disks crackle with detail! Along with the other FDs, I really enjoy the H alpha surface closeups.
Cheers, Peter.
Cheers, Peter.
