Chromosphere September 16th
- Has thanked: 9144 times
- Been thanked: 6025 times
Hello everybody: I was out this morning for a quick session. I scanned the disk and I found only one small active region, in the first two images. The last two are wider views of the chromosphere.
Seeing quickly deteriorated around 10:00AM.
Clear skies to all
Clear skies to all
- 091856 final mono.jpg (231.38 KiB) Viewed 2062 times
- 091856 final color.jpg (392.72 KiB) Viewed 2062 times
- 092055 final mono.jpg (1.39 MiB) Viewed 2062 times
- 092055 final color.jpg (2.47 MiB) Viewed 2062 times
- Chromosphere final mono.jpg (1.25 MiB) Viewed 2062 times
- Chromosphere final color.jpg (2.31 MiB) Viewed 2062 times
- 095006 final mono.jpg (1.26 MiB) Viewed 2062 times
- 095006 final color.jpg (2.1 MiB) Viewed 2062 times
- Has thanked: 20424 times
- Been thanked: 10243 times
Re: Chromosphere September 16th
Looking good Franco! Another cloudy weekend for me.
Small AR's are fine!
They looks even better with larger telescopes and not less impressive than large spots in small telescopes.
- Has thanked: 8415 times
- Been thanked: 8161 times
Nice set of images, Franco. Good to see some activity at any scale.
- Has thanked: 17666 times
- Been thanked: 8787 times
- krakatoa1883
- Has thanked: 153 times
Very detailed images, Franco, well done!
Thank you, Alessandra and Raf, for your nice comments. Alessandra: I was not aware of that small AR but was happy to find it....any surface feature is very welcome these days.
- Been thanked: 4340 times
Great captures Franco
Thank you, Brian !
I was looking at this image a bit more closely and it seems to have almost like an oval pattern around the central active area. Is this just my imagination ?
- 092055 oval pattern.jpg (1.4 MiB) Viewed 1883 times
- Been thanked: 4904 times
- Been thanked: 171 times
Interesting Franco I don,t think it’s your imagination I see it clearly in the first shots .
Hi Franco...
I missed replying about the oval but there certainly seems to be a pattern there.
