This is my first attempt at a Halpha animation. Data capture was Sunday (10/7) between 1:17 and 2:02PM EDT. I did 10 seconds every minute for 45 minutes and ended up with 23 usable frames as seeing was pretty lousy. Here's the gear list for this capture:
Zeiss APQ130/Solar Spectrum Mod T-Scanner 0.6A FWHM/Baader TZ4/Astro-physics ERF/Astro-physics Mach1/PGR Grasshopper 3
Constructive criticism highly welcomed!!
Chris
Whirling Prom Animation 20181007
- Christopher
- Has thanked: 33 times
- Been thanked: 34 times
Christopher
- Has thanked: 9387 times
- Been thanked: 6201 times
- Christopher
Re: Whirling Prom Animation 20181007
Hi Skyburner,
Yes! That’s amazing. I absolutely had a vision of whirling dervishes when I first saw the 45 frames in sequence and your rendition nails it. Thank so much! I used FireCapture, Autostakkert, IMPPG (sharpening), Photoshop (align and animate). I’m sure with time one develops patience but boy I’ll tell you, the first time around I just knew I had something and wanted to see it move I can see that I way undersharpened. And level adjust totally makes sense. From what you’re saying I gather I could load the 45 final frames in RegiStax and avoid having to manually align them in PS. Is that correct?
Thanks to you Franco!
Christopher
- robert
- Has thanked: 4 times
- Been thanked: 1287 times
Lovely animation and great additions. I would add that ImPPG is very good for aligning frames too, anyhow all very interesting
Robert
menu item screen to use for aligning
Robert
- Christopher
Terrific. Many new things to try. I really appreciate all the feedback.
Christopher
- Has thanked: 20962 times
- Been thanked: 10592 times
Lovely results Christopher!
- Christopher
Based on lots of great feedback here I've learned some new techniques and reprocessed this animation. I must say, the event takes on a bit of a different character. Rather than whirling proms, one sees quite clearly the massive double magnetic pulse unleashed through this prom group. Each of those pulses lasts just under 5 minutes in real time and they' occur about 20 minutes apart (the more powerful burst is first in sequence). Makes me wonder what I missed as I got clouded out at the end and still had some SSD space left This is all 44 frames (good and bad).
Christopher
