I watched these proms today too, they were lovely, not quite what yesterday's monster was, but still great for a minimum!
Was this with a chroma?
Cool calcium prom 11-13-2018
- Has thanked: 1188 times
- Been thanked: 1382 times
- krakatoa1883
- Has thanked: 153 times
Re: Cool calcium prom 11-13-2018
Fine prom video, Apollo.
- Has thanked: 8559 times
- Been thanked: 8290 times
Nice calcium proms, Apollo.
- Been thanked: 4427 times
The CaK prom is great to see Apollo
The dark specks are typical of dust in the optical path (in 'the spot' clip), and should likely lie close to the chip based on their small size. The half circle artifacts look strange...very uniform in size and appearance. Will be interested to know what caused them. If you capture with Firecapture or similar software these can be removed quite nicely with flat fields...the dust specs at least. No promises on the other ones.
