Dec 26 Prominence Animation
- Christopher
- Has thanked: 33 times
- Been thanked: 34 times
Another clear day coinciding with available time - wow, not only the sun was shining but Lady Luck too! But luck always has it limits I set up early but misjudged the sun's trajectory over the tree tops so had to pick up the rig and move it, then realign, etc. etc. Then the software gremlin showed its ugly head again and required that I uninstall/reinstall FireCapture and the SSM plugin - not once but twice before I had a functional camera. It seems the SSM plugin is the problem - awaiting on some feedback from the developer. The seeing was mostly bad but made the most of it. I used the Lunt LS100THa doublestacked with the Solar Spectrum modified T-scanner for FDs as well as the Zeiss APQ130 set-up for prominence close-ups. I even tried some white light with the Herschel wedge to try to capture convection cells but not much luck there. I think it requires better seeing and a longer focal length than what I used. That said, here's a prom animation that turned out OK. Technical details included at the link.
Thanks for looking!
Thanks for looking!
Christopher
- Has thanked: 9417 times
- Been thanked: 5583 times
Re: Dec 26 Prominence Animation
Hi Christopher,
Very nice active Prominence.
Rainer
Rainer
- Been thanked: 4340 times
Sounds like you had more than your share of problems trying to get up and running, but the animation certainly paid off. Nice work
- Has thanked: 8418 times
- Been thanked: 8165 times
Nice work, Christopher.
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Christopher,
yes that SSM pluging can give a problem. If you startup FC and the pluging is still enabled it will freeze capturing. Just go to to plugins, unselect it.
FC will then work ok, then you just select the plugin again and everything works.
Had the same problem, and it took a while before i found a way to get around this,
- Has thanked: 20442 times
- Been thanked: 10248 times
Nice animation!
- robert
- Has thanked: 4 times
- Been thanked: 1274 times
Exactly my own experience with the plug in.PDB wrote: ↑Sat Dec 29, 2018 7:39 am Christopher,
Nice animation Christopher
Robert
- Has thanked: 9145 times
- Been thanked: 6027 times
- Christopher
Thank you for your comments. I had wondered about the switching the plugin off and on approach. I will try it when the next opportunity avails. I’m experiencing a few other issues with the plug-in as well, one of which would at times preclude this remedy. I will list them in a separate post.
Thanks!
Thanks!
Christopher
- Been thanked: 8793 times
What a wonderful animation, I really enjoyed that and especially as it took so much work to get it
I watched Gremlins last night by the way
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Nice proms animation. I appreciate them better knowing the context of capturing them.
Alfred
Alfred
- Christopher
Thanks Alexandra and Alfred. Yes, sometimes the story must be told, no matter how gruesome
Christopher
