Lunar New Year Sun from Singapore (6 Feb 19) - New Image added
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
We had good weather on Lunar New Year holiday (5 and 6 Feb 19) here in Singapore. There were just too many festive matters to attend to on the first day. I managed to do some imaging on the second day of the holiday.
In this period of the solar minima there was no fireworks. A lonely plage was visible in the chromosphere. No sunspots though. Still looking out for signs of next Solar Sunspot Cycle. Here is the Sun in 3 colours and the equipment used for imaging them.
In preparation of the new cycle, I decided to "exercise" the high-resolution gears. Unfortunately the seeing wasn't that great. Here are the high-resolution images in HA and CAK and the equipment used.
(You would need to do a right click to open the images in full resolution. Enjoy them.)
I have posted images from 4 sets of equipment (i.e. SF50 DS on a Borg 77, CAK and WL on a Megrez 90 and Celestron 150mm Omni XLT with a Lunt 50). The high-resolution CAK image was taken with a 60mm Jason Rotary Power Astronomical Telescope 1000mm FL, compensated for CAK wavelength. This is the first time I am posting images taken with this setup.
I hope to start "exercising" the C8 fitted with an ARIES D-ERF and C14 also fitted with an ARIES D-ERF soon.
- Has thanked: 9145 times
- Been thanked: 6026 times
Re: Lunar New Year Sun from Singapore (6 Feb 19)
Very nice sharp images, Alfred ! Interesting equipment also...
Like Franco wrote: nice and sharp!
What do you mean by "compensated for CAK wavelength" for the 60mm? Don't see your Lunt diagonal on the picture of the 60mm set up, did you use CaK filter? CS! Bart.
- yltansg
Hi Bart,
There is an internal 36mm Baader Planetarium B-CCD ERD mounted inside the telescope followed by a 1.25" 2.4 angstrom CAK filter.
Alfred
- Has thanked: 20442 times
- Been thanked: 10248 times
A great collection of images and scopes Alfred! Have a great holiday.
- Been thanked: 8793 times
Happy Lunar New Year Alfred what a fantastic collection of images, looks like you had great fun
- Been thanked: 4340 times
A great set of images and thanks for sharing photos of the equipment you use
Happy New Year too!!!
- yltansg
Thanks Franco, Mark, Alexandra and Brian for your kind comments and well wishes.
Alfred
Alfred
- Been thanked: 4904 times
Alfred:
Super shots and setups.
Best wishes and regards to you.
- yltansg
Here are 2 different images using the 60mm refractor in CAK:
136 frames stacked and processed in PS
1000 frames stacked and processed in PS
Re: Lunar New Year Sun from Singapore (6 Feb 19) - New Image added
Nice additions Alfred
