Finding Scopes That Are Well Corrected For Ca-K Imaging
David_The_Bears_Fan
Has thanked: 423 times
Been thanked: 167 times
Post by David_The_Bears_Fan »
Simple question, when looking at potential new scopes is there a way to tell if it will be sufficiently well corrected for Ca-K imaging? My assumption is the only reliable way to tell is to try it, which is kind of limiting. Thinking of moving from my achro Skywatcher Evostar to something like an F/10ish ED but whatever I buy must work for Ca-K imaging.
David
Has thanked: 20738 times
Been thanked: 10428 times
Re: Finding Scopes That Are Well Corrected For Ca-K Imaging
I think you will struggle to improve on what you have without spending big bucks...
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Maybe a 150 mm F/8 (or 10) Newtonian telescope with a sub-aperture ERF in front of the secondary mirror is the way to go.
bart1805
Been thanked: 1 time
Post by bart1805 »
Hi David,
Here is an interesting thread about this question:
viewtopic.php?f=10&t=25115&hilit=small+scopes+cak
If money is no problem I would go for a TOA 130 or 150. A nice entry, often offered secondhand, is a Synta 100mm ED f/9.
CS! Bart.
David_The_Bears_Fan
Thanks Guys
@Mark - Had crossed my mind. I was actually considering the upgrade to try and up the quality of my white light images (removing some of the losses caused by chromatic aberration) but do not want to adversely impact my Calcium imaging.
@Bart - great thread with some interesting links, thanks.
David
The other way to look at this is to improve the overall quality of the data you are are recording; you could get a SSM http://astrograph.net/epages/www_astrog ... ccessories
Does the 178 camera support binning? The native pixel size is small and suited to short focal ratios, binning would increase the fps and sensitivity, reducing exposure time.
Going above the 120mm aperture you have already, the seeing is always going to be the biggest factor.
Are you using a continuum and UV filter with your whitelights?
