Saturday Sunshine - 23rd February
- Has thanked: 20819 times
- Been thanked: 10489 times
Hi Everyone.
Some nice weather this saturday! Not the deep blue skies I had in Italy earlier in the week, more of a milky haze, but still acceptably clear for solar imaging. The sun is all but clear of the majority of the trees now so my solar season can begin properly finally. This morning was pleasantly warm but the seeing was not great and I quickly resorted to the SSM to get only the best frames. First up I shot a full disk with the SM90, the filament and plage easily visible. The poor seeing manifesting itself in the spicule layer being a fairly continuous line rather than clearly defined spicules.
ha-full-disk.bw by Mark Townley, on Flickr
ha-full-disk-colour by Mark Townley, on Flickr
Then I wanted to try the Quark with the SM90 as a double stack. It works well.
image by Mark Townley, on Flickr
With a lack of proms the natural target was the filament and plage:
filament-limb-ha-bw by Mark Townley, on Flickr
filament-limb-ha-colour by Mark Townley, on Flickr
There appeared to be a ephemeral region that marks the likely magnetic other end of the filament structure:
filament-ha-bw by Mark Townley, on Flickr
filament-ha-colour by Mark Townley, on Flickr
Then I switched to CaK, the sun was starting to quickly go behind the trees (shadow on bottom right of disk), but I was pleased to see the PGR GH3 could accommodate the 1000mm focal length used for this full disk. Seeing was not up to the 80mm aperture used here, but it gives an idea of what is possible when the seeing complies. If tomorrow is good I may give 60mm a try.
cak-full-disk-bw by Mark Townley, on Flickr
cak-full-disk-colour by Mark Townley, on Flickr
Finally zooming in with the 2.5x barlow on the plage.
cak-plage-bw by Mark Townley, on Flickr
cak-plage-colour by Mark Townley, on Flickr
All in all pleased with this mornings run!
Re: Saturday Sunshine - 23rd February
DS images are great for such a condition. Excellent session.
- Been thanked: 4427 times
Hi Mark...
A great set of images and good to hear the sun is more accessible for you again!!!
The DS through the 90mm looks fantastic
- Has thanked: 1188 times
- Been thanked: 1382 times
- Has thanked: 2464 times
- Been thanked: 4880 times
Mark,
All great images! Superb DS performance in my opinion. Looks like it's going to be a good solar season this year.
- Christopher
- Has thanked: 33 times
- Been thanked: 34 times
Very nice set of images Mark.
Christopher
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Great set Mark. The Quark / Solarmax double stack setup seems to work quite well.
David
Thanks everyone! Hoping Sunday yields me some more sunshine too!
- Has thanked: 8559 times
- Been thanked: 8290 times
Looks like you had an excellent session, Mark, even in milky skies. Very nice images across the spectrum. At least you’ve (mostly) cleared the treetops
The sky was a bit too hazy here and it turned cloudy in the afternoon. Maybe Sunday.....
Stu
Stu
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
- Has thanked: 9319 times
- Been thanked: 6157 times
What a great session, Mark. You are definitely having fun with your SM90.
Franco.
Franco.
A great set of images Mark, I think your 90mm double stack image looks absolutely identical to mine (I didn't copy yours honestly )
Interesting to see your CaK too, it is good to compare with mine.
- Has thanked: 541 times
- Been thanked: 811 times
The DS w Quark/SM90 is amazingly good!
I'm also envious you have such good weather. We're not going to get much above freezing for another two to three weeks...
Bob...you've got way more snow than me based on your pic! Rain this weekend has melted a lot and now a massive wind storm (could get over 100kmh tonight)...likely picking up shingles in the morning and calling the roofer.
