Sun Hα 6562.8 Full Disk By Alexhy
Date&Time:UT+8 2019/2/24 (Four pictures mosaic)
Equipment:70Q APO F6+ES3X+Combo Quark+ ASI174MM
2019/2/24 SUN Halpha Full disk
- Has thanked: 2 times
- Been thanked: 347 times
- 2019-02-24-02.jpg (1.88 MiB) Viewed 1065 times
- 2019-02-24-01.jpg (4.93 MiB) Viewed 1065 times
Re: 2019/2/24 SUN Halpha Full disk
Welcome here, Alex.
Congratulations with a debute in solar imaging.
To make you system work better you need more F/D at the Quark. Something 30 to 45.
Then the images will be MUCH more contrasty. The next step is to use black/white camera instead of color one.
Hope this helps.
Hope this helps.
Dear Valery,
this F/D 30 SUN Flare(SUNSPORT AR2673 ),
qhy174MM
thanks!
Alexhy
- 2017090503.jpg (2.71 MiB) Viewed 1038 times
- Has thanked: 9145 times
- Been thanked: 6025 times
- Been thanked: 10248 times
Top shots indeed!
- Been thanked: 4340 times
Nice set of image Alexhy!!!
- Been thanked: 8792 times
