Photoshop settings for Ca color?
- Has thanked: 1640 times
- Been thanked: 878 times
Re: Photoshop settings for Ca color?
No, you can't get a true color for CaK. Computer monitor create a violet as deep purple - the mixture of blue with a doze of red. This is not what real CaK line produce!
So, only imitation: fully remove green, remain blue and add some red.
- Been thanked: 4427 times
Visual CaK is tough due to the limited sensitivity the eye has with this wavelength.
As Valery says, no green and only a little red makes a reasonable match to what my cataract corrected eye actually can 'see' at the eyepiece. Everyone has their own interpretation
