Hi all...
I was just on the GONG site and see that there is a bright bit of activity quite high in the northern disk near the central meridian...appears in both the Learmonth and Mauna Loa images. Is this associated with cycle 25 ?
Latest GONG Images
- Been thanked: 4419 times
Latest GONG Images
- Has thanked: 20767 times
- Been thanked: 10453 times
Re: Latest GONG Images
There's a good chance with high latitude activity like that. Just need the magnetic data to update so can see polarities...
- Has thanked: 17970 times
- Been thanked: 8902 times
It looks reversed to me, it is actually the same way round as the southern hemisphere polarity. Looks like a cycle 25, well spotted Brian.
Good info Alexandra!
In the images, which is the pos and neg pole...the bright foot print or the dark?
I shared the image above to Scott William McIntosh and asked him 'signs of cycle 25?'
His reply; 'Possibly - I anticipate that by the end of the year we’ll have a few longitudes where it’ll be clear! Need the terminator to happen (early 2020) and we’ll talk about the 9.5 year long cycle 24....'
Black denotes a negative polarity (magnetic field pointing into the Sun) (south polarity) while white denotes a positive polarity (magnetic field pointing out of the Sun) (north). Large concentrations of both polarities are found near active regions and sunspots.
http://solar-center.stanford.edu/solar- ... grams.html
Derek and Alexandra...
Thanks for your comments and information about the specifics on the polarity of the new and waning cycles.
