Hi guys,newbie from Norway here.
Just got my self a cheap solar wedge to see if this is something for me , and i have read that no filter should go in front of the wedge, but still i have read that someone puts the uv/ir filter in front, maybe this filter doesen't stop the heat from going through?
Could this be right? Or did i read this wrong? Mine is threaded in the front.
Haven't used mine yet , due to heavy rain.
Thanks in advance.
All the best.
G
Were to put uv/ir filter?
- Has thanked: 174 times
- Been thanked: 619 times
Re: Were to put uv/ir filter?
More important than the UV-IR is the mandatory ND3 filter.
You can fit an UV-IR after the ND3 if you feel concerned.
- Oh, I get it now!
- Has thanked: 24 times
- Been thanked: 22 times
The ND3 filter is preinstalled , so no problem there :-)
But i have been Reading a lot on forums regarding the use of diffrent kind of filters , and how some can help on contrast , and since i already have some of them , i thought i would try to use them.
I have an eyepiece extension tube that i can use for a filter,since my filters can't be stacked / screwed into each other .
And that is the reason i asked about mounting the uv/ir filter in front , as i wouldn't need to use the extension tube , but since my solar wedge didn't come With a user manual , i read other brands manual ,and they say no mounting of a filter in front of the wedge.
But i read that some do it anyway with the uv/ir filter , that's why i asked.
I thought i try a #green 56 (don't have #58) paired With the uv/ir filter , but i also have cls , uhc , variable polarizing filter , 2 other polarizing filters and a coloured filter set/kit and my Club has a lot of others that i may be allowed to test out before i buy my own , if i find them to work , crazy prizes on some of them.
The Scope i will test out is an achromat ,Aquila 90 / 500 , but i also have an sky watcher st 120 i could use , but i would have to take it Down since the recomended size is 100 mm.
Welcome here,
My UV/IR filter is in the front of the wedge on telescope side, the other filters ND3, Baader Continuum (lime green) in the back of the wedge on eyepiece side.
- Been thanked: 10489 times
I'd use the uv/ir on the front of the wedge...
- Been thanked: 4427 times
Welcome to the group!
In my case, I have the UV/IR cut filter and Baader continuum filter installed at the bottom of the eyepiece holder so that I can switch form eyepiece to camera without having to change the filters.
- Oh, I get it now!
Thanks guys , that helped a lot , tried to take some Pictures today , but i zoomed in to much i think ,using a canon 1000D.
Well i have to keep Learning .
Visual was good , but not much action .
I will have to experiment With both eyepieces and filters, but will leave my uv/ir filter at the front of the wedge.
i will probably buy the Baader Continuum filter , but i have to wait a while since i spent to much lately
Thanks for Your help.
All the best.
G
All the best.
G
