Heya,
It's been raining and nasty here in Florida, but this afternoon, I left work early and the sky cleared up as it got later, around 1730 in the evening. Seeing was not great, but it was manageable. AR2737 has evolved into a fairly nice little spot with visible umbra and some interesting plages and filament activity around the area.
Equipment:
C8 Edge HD (masked to 150mm) with 0.7x Edge Reducer + Aires Tri-Band D-ERF + Baader UV/IR Block Filter
ST80 (masked to 60mm)
Quark Chromosphere
ASI174MM + 0.5x Focal Reducer
AR2737 & Full disc | HA | April 2nd 2019
- Has thanked: 1188 times
- Been thanked: 1382 times
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Re: AR2737 & Full disc | HA | April 2nd 2019
Thank you so much ! Fantastic ! I am going to try and get some practice with deconvolution and processing to see how my system matches (Quark Chromosphere/ED70 and ASI120mm-S on a slow laptap USB2.0.
Thanks!
Magnus
London
Thanks!
Magnus
London
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- Has thanked: 20779 times
- Been thanked: 10462 times
A good set there Marty!
- Been thanked: 4422 times
Another great set of images Marty
- Has thanked: 8543 times
- Been thanked: 8280 times
Good images, Marty.
Nice setup.
Nice setup.
