Heya,
It was cloudy and nasty this morning, but then it broke around the afternoon after 10am and I was able to get some sky time. I fully expected the seeing to be terrible, but to my surprise, it was quite good. I guess my summer seeing is finally coming in a little early. I was able to use the full 200mm aperture of my system for the high resolution images in both HA & WL (both are in 656nm) and have finally surpassed my previous 150mm refractor's resolution thanks to good seeing. AR2738 flared while I watched and I captured some sequences that was really interesting. The flare moved so quickly that I watched it happen over mere seconds, and within 2 minutes, it was moving so much that I knew I couldn't go for long captures for a stack and had to keep it short. I was able to switch over to white light and imaged AR2738 and the convection cells. I also grabbed a little bit on AR2737 for good measure just because it's still there. The full disc was a disaster, barely got it between clouds, and also my imaging scale is way off for my pixel size, but I was testing a new system there (Double Stack PST). I need a new camera with tiny pixels to do full discs with the PST. There's a fairly large prominence on the limb, but the clouds came in quickly and I didn't have time for that one.
B&W:
Colored:
Flare Animation:
Earth Scale:
Equipment:
High Res Hydrogen Alpha (Chromosphere):
C8 Edge HD + Aires 200mm Tri-Band D-ERF + Baader 2" UV/IR Block Filter
Daystar Quark Chromosphere
ASI174MM + 0.5x Focal Reducer (F21)
High Res White Light (Photosphere):
Baader 1.8 ND filter + Baader 610nm filter
ASI174MM + 2.0x Barlow (F20)
Full Disc Hydrogen Alpha (Chromosphere):
PST + SM40II Double Stack
ASI174MM (way, way under sampled)
AR2738 (Flaring! Animated) in High Res, HA & WL | April 8th 2019
- Has thanked: 1188 times
- Been thanked: 1382 times
- Has thanked: 20779 times
- Been thanked: 10462 times
Re: AR2738 (Flaring! Animated) in High Res, HA & WL | April 8th 2019
Good captures Marty! I was hoping earlier today you were getting a view in to share, just cloud and grey for me today unfortunately.
- banjo
- Has thanked: 2100 times
- Been thanked: 2876 times
Very good captures Marty,bravo!!!!!
A serie of beautiful images Marty.
- Has thanked: 8543 times
- Been thanked: 8278 times
Very nice images, Marty.
Congratulations on your Space Weather article today.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Great images, really impressive
Raf
Marty, I believe this set of images captured substantially finer detail than is possible with a 6" scope. Images like these makes the journey worthwhile. Looking forward to seeing more.
Phil
Phil
- Been thanked: 4419 times
Hi Marty...
These are superb Ha and WL images
Congrats on the SpaceWeather appearance too!!!
