Before the clouds 13 April
- Been thanked: 4786 times
These images are a mix from different imaging settings.
150mm scope
Quark Chromosphere
ASI 174MM with and without reducer
150mm scope
Quark Chromosphere
- Has thanked: 20424 times
- Been thanked: 10243 times
Re: Before the clouds 13 April
Fine images Maurits!
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Fine images, Maurits, well processed.
Raf
- Been thanked: 4340 times
Great shots Maurits
- pedro
- Has thanked: 14 times
- Been thanked: 6576 times
Great HR H-alpha images Maurits, your Quark Chromosphere is a keeper, mine had to be sent for repairs
Pedro Re'
- Has thanked: 9144 times
- Been thanked: 6025 times
Very, very sharp images, Maurits. What programs do you use for the post processing ?
Franco, I usually use FireCapture or SharpCap for the recording.
Then I run AutoStakkert and most ImppG (sometimes Registax 6) and a little bit sharpen in PS CS6 ... that's all I do.
For me, the most important thing is take time when I FOCUS the telescope.
Especially a lot of patience when I'm waiting for the temporary better seeing.
I look to the display and sometimes I can count the seconds when the better seeing returns, there is exactly a certain regularity in the seeing and then take a record at the right time.
Remember: Only a sharp picture can be made even better, a blurry photo remains a lesser picture after what sort of post processing you do.
- Davidm
- Been thanked: 289 times
Good stuff Maurits. I like the 'frothy' part of the active region as much as the sunspot.
Lunt LS152T (DSII and CaK module), Coronado Helios 1, Grasshopper 3 2/3" CCD
- Has thanked: 8415 times
- Been thanked: 8161 times
Very fine images, Maurits. Well captured!
