I have finally got an image I am pleased with using Bobs ebay filters.
The seeing was bad and I only got 30 mins before the sun hit next doors house.
The big problem I have had is vertical lines caused by the QHY5II-M seems a big problem with this camera.
So I orientated the image that it would drift across the lines with the drive motor speeded up and then when staked the lines will be in different places on the final image and they will not stack. I can then use Registax wavelets to bring out some detail. This worked a treat.
Not as good as a Quark but does work so now a Quark and D-ERF is next on my list when I have passed that past the boss
The image was taken with my Carl Zeiss Jana 150mm f15 Coude stopped down to 110mm f20.
Th filter system uses a 50mm UV/IR, 630 Red, Bobs blocker 25mm, Bobs (etalon) filter, KG3, Bobs second (etalon) filter.
No collimators or telecentric.
Camera QHY5II-M
Image is a stack of 20 frames 800x600 from 1000 at 25 fps using EZPlanetary, Staked with AutoStakkert, Registak Waves, Ps cs6 to finish.
AR2740 with Bobs filters
- Has thanked: 20442 times
- Been thanked: 10248 times
Re: AR2740 with Bobs filters
Missed this one! Nice shot.
- Has thanked: 286 times
- Been thanked: 399 times
Thanks Mark
For a while I never thought the filters were ever going to work.
But now I can see something I have the solar bug.
When I had one of the first PSTs I always thought about ripping it apart and was sure it would work but there was not enough info back then no one had done it.
What I have learnt from this project is that aperture beats f ratio with these filters, f30 is not needed, it works well at f15 when the seeing is good.
Also the more optics the more problems, keep it simple.
Next will be a Quark combo and hopefully a Baader D-erf then I may catch you up.
Cheers
Cheers
- Has thanked: 17672 times
- Been thanked: 8793 times
Nice image Rod, looks like you put a great deal of effort into this
Thanks Alexandra
yes it has been a lot of work but interesting
It also works on proms quite well
- 16-49-38-897 21stack Corono wavelets crop PSP colour.jpg (92.44 KiB) Viewed 981 times
Nice addition with the proms
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4787 times
