Hi solar imagers
On a totally blank sun face the CaK and CaH offer more to see, especially at a high resolution.
Here is a recent image of the sun (near the center of the disk) I took in CaK line at a high resolution.
The angular resoluton at CaK line 393nm is 1.67x higher than at H-a 656nm. So, my C11 280mm telescope
has the same resolution as a 468mm telescope in H-a line.
I was lucky to take several images where a full resolution has been achieved. This image is one of them.
Right click on the image and choose "open in a separate window" to see the image at a full resolution.
Thanks for looking.
Valery.
For CaK funs. Mini activity at High Res 280mm aperture.
- 09h-15m-ARIES-295mm-DERF-C11-PST-CaK-DS-ASI290.jpg (283.37 KiB) Viewed 1056 times
- Been thanked: 4434 times
Re: For CaK funs. Mini activity at High Res 280mm aperture.
Very impressive Valery, the details are very sharp and remarkably angular
- Has thanked: 20834 times
- Been thanked: 10503 times
That's excellent Valery! Very much like DOT images. You are at the cutting edge of hi-res solar!
- Been thanked: 4881 times
- Has thanked: 8559 times
- Been thanked: 8297 times
Remarkable image, Valery.
- Been thanked: 4981 times
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Dear Valery,
That is superb CAK imaging. Congrats!!! What is your imaging train like? (e.g. from the output of the SCT to the camera).
Alfred
Alfred
- Been thanked: 8907 times
WOW!! superb!!
What Barlow/telecentric did you use to achieve this?
