July 7th Images
- Been thanked: 4427 times
July 7th Images
Good day everyone...
It has taken most of the week to process the image sets captured last Sunday...maybe a week of 'spring rush' left at work...dragged well over a month late compared to most years with the clod, wet spring. Last Sunday was a beautiful clear day, though the seeing wasn't great it was better than I expected. With the prospect of seeing the new AR associated with the new solar cycle I ducked out to the observatory after breakfast and spent the morning viewing and imaging.
The first set of images are full disks. The Ha was taken through the LS80T/LS75FHa/B1200Ha solar scope and the PGR camera (ICX674 chip). This is a composite image with a longer limb exposure to pull up the fainter proms (limb inverted): The next full disk images are through the iStar 150mm/f8 OTA using a Lunt Solar Wedge/Baader Continuum filter for the WL images and a modified Lunt Solar Wedge/B1800CaK module/Baader K-Line filter set. Both used an ASI1600MM camera. While the iStar was on the Sun I imaged the developing AR in WL and CaK with a 3x tele-converter and the ASI174MM camera: I switched over to the modded CR-150/DSII/B1800Ha and the 3x tele-converter/ASI174MM to see fruits of the Ha spectrum. Initial images did not show a lot of detail, so I swapped the B1800Ha blocker for the Quark Combo to DS the scope, and this made a significant improvement in the ability to see the details. I made a few mosaics of the regions of interest, specifically the developing AR, filaments approaching the western limb, and a small spot of activity on the SW quadrant. The DS setup requires long exposures and I ran the camera in binned mode for these images: Quite a nice session with the new cycle showing signs of life
Now, I think I have some unprocessed prom images...I better see what happened to them!
- Has thanked: 20819 times
- Been thanked: 10489 times
Re: July 7th Images
These are super images Brian! A very productive session.
Re: July 7th Images
Thanks Mark
It was a good session indeed, and offered up multiple targets to image too!!!
- Has thanked: 9319 times
- Been thanked: 6157 times
Re: July 7th Images
Thanks Franco, always appreciate the feedback
- krakatoa1883
- Has thanked: 153 times
Re: July 7th Images
Nice images, Brian, I liked H-alpha in particular. WL and CaK appear quite dark on my screen, they could be improved by using of curves tool or a high pass filter. I tried to do so but some artifacts emerged at the top limb of the full disc. At full resolution CaK is impressive, very well resolved.
- Has thanked: 8559 times
- Been thanked: 8291 times
Re: July 7th Images
A fine set of images, Brian.
- banjo
- Has thanked: 2100 times
- Been thanked: 2878 times
Re: July 7th Images
Re: July 7th Images
That is a super solar harvest Brian, you got some lovely close ups of the new cycle spot and some delicate little pores in the WL shot, well done!
Re: July 7th Images
Thanks for all of the comments everyone...always very much appreciated
Raf, I was tempted to adjust the brightness before posting but thought it look like these two specific images would look ok...should have spent more time after all. I had a lot of trouble getting the large CaK/WL images to stack without the artifact, and after locking up the computer on several attempts to redo them in several programs I just used the only attempt that worked.
Re: July 7th Images
Thanks for your feedback Phil...always appreciated
- Been thanked: 171 times
- Has thanked: 2464 times
- Been thanked: 4880 times
Re: July 7th Images
Derek and Maurits...
Thanks for your comments, always appreciated
