First reasonable FD
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
First reasonable FD
Post by MAURITS »
This is my first FD ever.
Before I could not make an FD recording with the original small Lunt LS35F ha scope and the ZWO 120MM camera.
So, I have remove the Lunt LS35F etalon and with a perfect adapter I coupled it to the Little Takahashi FS60 CB scope.
The Lunt blokking filter is the same BF600 as before.
The difference "visual and imaging wise" is huge, the sun is much much bigger in de scope than with the original Lunt 35mm scope, is a lot sharper too and with the telescope focusser it's easy to come in focus this time, before it was a helical focusser with not enough infocus (that was my problem).
This is a quick recording from this morning with a very quit sun.
No flatframe calibration needed, just a daystar eliminator to prevent newton rings.
FD Gray.jpg (114.34 KiB) Viewed 988 times
FD Color.jpg (128.61 KiB) Viewed 988 times
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 17901 times
Been thanked: 8888 times
Re: First reasonable FD
A super full disc! nice contrast :bow :hamster:
MAURITS
Post by MAURITS »
Thanks Alexandra.
Maurits
xn44
Post by xn44 »
Congratulations Maurits!!!
MAURITS
Post by MAURITS »
Thanks Pepe.
Maurits
Has thanked: 20738 times
Been thanked: 10432 times
Nice setup and good start there Maurits!
Has thanked: 9280 times
Been thanked: 6127 times
Post by ffellah »
Great first full disc, Maurits
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Nice full disk wit the new setup Maurits :bow
MAURITS
Post by MAURITS »
Thanks all for the nice comments.
Maurits
