Here are a few more images taken with my c9.25 with a Quark Combo on a 3X telecentric with an Orion 0.8X focal reducer.
Lou
On the sun's limb on July 25
- Been thanked: 1735 times
- Has thanked: 20779 times
- Been thanked: 10462 times
Re: On the sun's limb on July 25
Nice shots of the edge Lou!
- Been thanked: 4422 times
Very nice Lou...must have been tough to get these at the long focal lengths!
- Has thanked: 3315 times
- Been thanked: 1907 times
I was doing a first test of a 90mm F6.7 with a 4x Barlow and a straight through PST Etalon on the 25th late morning in the UK.
I could see a region, sort of hedge prominence, on the bottom right for me, about twice the height of the spiricules.
Does that sound about right based on images taken?
Andrew.
Andrew.
Hi, Andrew
If I remember correctly, what you are describing sounds like the prominence in the 3rd image down which I spotted in the lower right of the sun's disk on my screen. I often reorient my images right side up no matter where they actually are on the sun. Did you take any images of that prominence?
Lou
Lou
I am still in modding mode. Mainly baffling out stray light as I like good contrast.
I have a little QYH but failed to find focus in one try on the PST some time ago.
I might try sketching.
As the Sun is dynamic its just nice looking.
My one bodge try on the 127mm at F30 what I could see was comparable with an image on here, maybe a little more contrast.
When the first cheap Chinese refractors came out lads were web-camming the planets.
You would look through the scope one week and see the images the next.
They were less sharp, contrasty and colourful than what you re-called seeing.
Andrew
Andrew
- Has thanked: 8543 times
- Been thanked: 8280 times
Nice shots, Lou.
- Has thanked: 17970 times
- Been thanked: 8905 times
Lovely fluffy spicules and you got all the detail in the small proms, nice work
