Hello all from Barcelona.
This is the last image.
Mini Poro 8 8 2019 11 19 TU by Pepe Manteca, en Flickr
Mini Poro 8 8 2019 11 19 TU RET by Pepe Manteca, en Flickr
IMAGE SDO HMI
SDO by Pepe Manteca, en Flickr
MINIPORE 2019 08 08
- Has thanked: 20424 times
- Been thanked: 10243 times
Re: MINIPORE 2019 08 08
You're getting some great white light views at this scale Pepe, the granulation is lush. Is this the one closer to the limb rather than the one more mid disk?
It's the trailing one, thought so. There is life in that cycle 24 equatorial band yet then
Were these with the c14 ?
yes S/C 14" Baader N:3.8, solar continuum double stacked and ASI174mm and many luck!!!!
It is not normal to have good image at 12.30 noon... I'm having good luck. Also the Christian Viladrich book, (Astronomie Solaire) gives very good advice.
S/C 14" when there is good image is a good setup, but also is awful when there is turbulence....
- Has thanked: 9144 times
- Been thanked: 6025 times
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4786 times
- Has thanked: 8415 times
- Been thanked: 8161 times
Nice work, Pepe. Lovely images of the tiny pore.
- Been thanked: 4340 times
Great resolution of all the granulation and that pore is nicely resolved...well done
- Has thanked: 17667 times
- Been thanked: 8787 times
