My first sun photo
My first sun photo
This is my first serious Solar photo.
I have a Lunt LS60 B600
The ring is 10 times more exposured
Pls advice what can be better(other blocking filter or double stack?).
Regards Hugo
Regards Hugo
- Has thanked: 20442 times
- Been thanked: 10248 times
Re: My first sun photo
That's a good start to the world of solar Hugo, welcome to the forum.
- Has thanked: 9145 times
- Been thanked: 6025 times
- Has thanked: 8418 times
- Been thanked: 8164 times
That’s an excellent first disk, Hugo. Lovely colour too and in my view it’s the way Ha images should be represented. 656.28 nm is red, after all.
Was this taken with a colour camera?
Generally we use monochrome imaging cameras, take an AVI video of a few seconds, use stacking software to produce a single image and apply image deconvolution/sharpening to optimise the image quality. You’ll see lots of examples on this forum.
With my Lunt 60 I generally image with a 2.5x Powermate on a Basler acA1920-155um camera with an IMX 174 sensor to make 4 or 6 pane mosaics. This brings out the optimal level of detail with this aperture.
Welcome.
Welcome.
- Has thanked: 2412 times
- Been thanked: 4787 times
- Been thanked: 8792 times
A very warm and sunny welcome Hugo what a wonderful picture to start with, some amazing proms on there
I too like the colour
The foto has made with ASI1600 mono sensor 17x13 mm and 3.8um pixel.
Photo is colored with Photoshop.
Next time I will try with powermade 5x
Regards Hugo
https://www.flickr.com/photos/162118128 ... 9470404526
Regards Hugo
With that camera i'd go with a 2x barlow, you will get a full disk in one and get good sampling for the pixel size.hugo52 wrote: ↑Fri Aug 09, 2019 10:08 am The foto has made with ASI1600 mono sensor 17x13 mm and 3.8um pixel.
Regards Hugo
- Been thanked: 6577 times
- Has thanked: 141 times
- Been thanked: 240 times
Love that giant prom on a full disk!
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
2x barlow, good advice, yes that must improve the optimal filling.
I wil try this first.
Regards Hugo
Regards Hugo
- Has thanked: 128 times
- Been thanked: 121 times
Much, much better than my first attempt.
About the biggest problem that you have is that there's simply not much to see up there right now.
It looks like you're doing well with the image capture. The rest is all about processing.
Alexandra (Montana) and Mark Townley, and possibly others, have posted very helpful solar imaging guides. They have helped me quite a bit
- Been thanked: 171 times
- Been thanked: 4340 times
Welcome Hugo...
You have a good first post with the FD image!!!
Start off slow...get the exposures and camera settings sorted out and then work your way up to barlows. I'm not sure what you have for a mount, but the more you push the camera/scope you will need to have a mount that can keep it all stable too So far the first step looks good!!!
