Hi all...
I was hoping for a more productive session today, but between clouds and computer shut down after a couple of full disk images and an attempt at some higher res shots.
Visually, the disk was pretty much blank in the LS80T/DSII/B1200 scope. I made separate disk and limb exposures to create the composite image below (limb inverted). There were a few small proms and small filaments, as well as a bit of an active prom around the 1'clock position where there is small disconnected piece floating above the lower parts of the prom:
I was hoping to pick up the proms in more detail but only managed to get a two frame mosaic of the northern part of the disk (poorly matched image quality). There are a few small bright regions and a little tuft of a filament, but this was the last of the frames captured:
Fro a different angle on the sunlight, I have attached a few images taken last night through the C14...Jupiter through an IR pass and Methane band filter and Saturn in the IR as well:
The jetstream was over head and although the previews looked good, the stacked images are not what I was hoping for.
August 11th Sun - a few angles
- Been thanked: 4340 times
- Been thanked: 4787 times
- Has thanked: 8418 times
- Been thanked: 8165 times
Re: August 11th Sun - a few angles
Nice images, Brian. I must try imaging Jupiter and Saturn sometime.
- Been thanked: 10248 times
These look great Brian! The planets are way too low for me at the moment, I need to wait several more years till they are higher in the sky.
- Been thanked: 8793 times
That's a lovely full disc and some nice hairy proms
I've never seen Jupiter look like that before, that is an amazing shot! lovely Saturn too
Nothing from me this weekend, rain, wind and cloud again. An amazing blue sky Monday morning though as usual.
- Has thanked: 9145 times
- Been thanked: 6026 times
A very good set, Brian. The planets came out great, with excellent detail.
Hi everyone...
Thanks for all the feedback and positive comments
- Been thanked: 171 times
Nice ones Brian Jupiter and Saturn are straight overhead down here at the moment.
Cheers Derek
Cheers Derek
