I haven't seen many images from the 12th. Maybe because there was not much to see. I was out there still trying to fine tune the LS80.
Here are a couple different images with different processing. You didn't miss much that day.
Phil
FD's September 12th
- Has thanked: 1198 times
- Been thanked: 1390 times
- Has thanked: 20908 times
- Been thanked: 10564 times
Re: FD's September 12th
They're excellent disks Phil! Hoping to get a few images myself this morning if the weather holds...
- Has thanked: 2496 times
- Been thanked: 4917 times
- Has thanked: 9369 times
- Been thanked: 6193 times
- Has thanked: 8587 times
- Been thanked: 8322 times
Looking good there, Phil. It looks like you've nailed getting on-band over the entire disk. Nice.
- Has thanked: 65 times
- Been thanked: 4444 times
Superb FD images Phil
As Stu says, the disk is very even...well tuned!!!
- Has thanked: 17920 times
- Been thanked: 17064 times
Very nice!
Thank you kind gentlemen. I am sincerely trying to improve my imaging techniques but as a budding perfectionist, I keep seeing room for improvement. ;-)
Phil
Phil
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Excellent captures, Phil.
We have 110 psi haze over here. Hoping imaging can resume when the plantation fires in Indonesia are under control.
Alfred
Alfred
