Hi all...
A very small selection of images taken over my lunch yesterday (October 1st). I had hoped for more time to experiment on the weekend, but the weather did not co-operate so I took advantage of the limited time to grab some full disk images. All are through the LS80T/B1200Ha/PGR ICX674 chipped camera, and are composites of separate disk and limb exposures.
The first was taken in the single stack mode, and shows a few faint proms and AR2749 which had just rounded the limb:
The next was taken in the double stack mode using the DSII module like it was meant to be used In DS mode it only makes a slight improvement in the disk features (the AR has more contrast and a tiny hint of a filament appears in the NE quadrant, but the proms seem to be a bit sharper and more evenly exposed despite the longer exposure compared to the SS mode:
That's all form the Monday session...looking forward to more clear days if the is AR will hold on
October 1st
- Been thanked: 4340 times
October 1st
- Has thanked: 1171 times
- Been thanked: 1360 times
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4787 times
- Has thanked: 17672 times
- Been thanked: 8792 times
Re: October 1st
Super discs Brian
I guess the double stack doesn't do much for the surface details as there aren't really any at the moment. I have wondered this summer whether my Solarscope DS is actually working but I think it is, the only to tell is by looking at the limb by this time next year I think things will start to hot up with the new cycle. Certainly with the double stack the plage is much brighter and I do prefer that image overall.
- Has thanked: 9145 times
- Been thanked: 6025 times
- Has thanked: 20442 times
- Been thanked: 10248 times
Re: October 1st
Good disks! Not weather for solar observing here.
Re: October 1st
Thanks for all the comments and feedback on the short session
