Quark Proms and Chrom Oct 10th
Starry Jack
Has thanked: 141 times
Been thanked: 240 times
Post by Starry Jack »
I got more experiments today with the Quark (and I used flats to boot!). SO many large proms today!
I experimented on the PROMS and the same CHROM ARs with Quark NEG 2 and Quark ZERO. The sun went behind a tree before I could get Quark POS 2.
The flats seemed to increase contrast as well...is that correct?
QUARK NEGATIVE 2 (best 50 of 200 frames though AS3 then IMPPG then GIMP).
08_45_15 Qneg2 no FR no Bar asi174 f27 152mm-4-5329 as3 to imppg to gimp.jpg
08_45_15 Qneg2 no FR no Bar asi174 f27 152mm-4-5329 as3 to imppg to gimp.jpg (138.26 KiB) Viewed 1655 times
08_46_02 Q neg2 asi174 f27 152mm-4-6227 as3 to imppg to gimp.jpg (230.66 KiB) Viewed 1655 times
08_46_54 Qneg2 no FR no Bar asi174 f27 152mm-4-6067 as3 to imppg to gimp.jpg
08_46_54 Qneg2 no FR no Bar asi174 f27 152mm-4-6067 as3 to imppg to gimp.jpg (74.91 KiB) Viewed 1655 times
08_47_26 Qneg2 no FR no Bar asi174 f27 152mm-4-6322 as3 to imppg to gimp.jpg
08_47_26 Qneg2 no FR no Bar asi174 f27 152mm-4-6322 as3 to imppg to gimp.jpg (179.93 KiB) Viewed 1655 times
08_48_05 Qneg2 no FR no Bar asi174 f27 152mm-4-5588 as3 to imppg to gimp.jpg
08_48_05 Qneg2 no FR no Bar asi174 f27 152mm-4-5588 as3 to imppg to gimp.jpg (131.69 KiB) Viewed 1655 times
08_53_26 Qneg2 no FR no Bar asi174 f27 152mm-4-11792 as3 to imppg to gimp.jpg
08_53_26 Qneg2 no FR no Bar asi174 f27 152mm-4-11792 as3 to imppg to gimp.jpg (472.9 KiB) Viewed 1655 times
08_55_29 Qneg2 no FR no Bar asi174 f27 152mm-4-564 as3 to imppg to gimp.jpg (198.35 KiB) Viewed 1655 times
08_56_25 Qneg2 no FR no Bar asi174 f27 152mm-4-5499 as3 to imppg to gimp.jpg
08_56_25 Qneg2 no FR no Bar asi174 f27 152mm-4-5499 as3 to imppg to gimp.jpg (469.04 KiB) Viewed 1655 times
QUARK ZERO
09_04_11 QZero no FR no Bar asi174 f27 152mm-4-11351 as3 to imppg to gimp.jpg
09_04_11 QZero no FR no Bar asi174 f27 152mm-4-11351 as3 to imppg to gimp.jpg (376.09 KiB) Viewed 1655 times
09_06_36 QZero no FR no Bar asi174 f27 152mm-4-939 as3 to imppg to gimp.jpg (172.11 KiB) Viewed 1655 times
09_07_29 QZero no FR no Bar asi174 f27 152mm-4-6078 as3 to imppg to gimp.jpg
09_07_29 QZero no FR no Bar asi174 f27 152mm-4-6078 as3 to imppg to gimp.jpg (535.84 KiB) Viewed 1655 times
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Re: Quark Proms and Chrom Oct 10th
Post by MAURITS »
Is there something wrong with most of the images?
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Starry Jack
Are they not loading?
Aeries D-ERF
12nm Filter
Has thanked: 20738 times
Been thanked: 10439 times
Nice shots of the proms Jack!
MAURITS
Post by MAURITS »
Jack, problem solved ...
Maurits
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Hi Jack...
Nice collection of images and the proms are a challenge when they are so faint, but you still pulled them up!!!
Has thanked: 17925 times
Been thanked: 8891 times
These are great, some super proms here :hamster:
I would say that neg2 is far more on band than zero (which doesn't look very nice - sorry). I would try negative 3, 4 and 5 next.
Starry Jack
Lol. No offense taken!!
Aeries D-ERF
12nm Filter
Starry Jack
Aeries D-ERF
12nm Filter
Has thanked: 8523 times
Been thanked: 8253 times
Jack,
Good images at neg 2. Maybe hold back on the deconvolution and apply more sharpening in ImPPG as you are introducing spotty artefacts into your images. I’ve found that these come in when the deconvolution scale is set too high and/or the number of iterations is set too high. The actual values depend on a number of variables. Play with the settings to see how they affect your image and use the zoom (plus) function to check the image quality in close. You should be able to pull out detail without introducing artefacts.
Hope this helps.
Starry Jack
Good stuff, Stu. Thank you. The large blobs are from the flats. I will indeed work on the small little round artifacts as directed.
Jack
Aeries D-ERF
12nm Filter
Starry Jack wrote: Mon Oct 14, 2019 4:15 pm The large blobs are from the flats.
You're not doing flats right if you're getting blobs.
Once the flat is set you can't change the focus, quark dial, rotate the camera etc. If you change any variables a new flat needs to be set.
Starry Jack
Crab nuggets. Ok! Good catch.
Thanks Mark
Aeries D-ERF
12nm Filter
Has thanked: 9293 times
Been thanked: 6128 times
Post by ffellah »
You are getting there, Jack !
Starry Jack
Thanks all. What's interesting is that the more I Practice the more I can see comments like Val's. But Alexandra's point is spot on, risk of a poor Quark in exchange vs the angst of exchange versus just pure enjoyment.
Cheers,
Jack
Aeries D-ERF
12nm Filter
