Plage Progression Through Cycle 24
- Has thanked: 8418 times
- Been thanked: 8165 times
I am indebted to Mark T for all of his wonderful Ca II K image data throughout the entire cycle, so everything that follows is based on his work.
Thanks, Mark.
What I've done is simply measure the amount of light coloured plage on the solar disk (as a percentage of total disk area) as a function of time to illustrate the ebb and flow of plage over the entire 24th cycle. For this I used a program called Image J and set the upper and lower lightness thresholds for each individual image in order to isolate the regions of interest (light coloured plage). It isn't perfect and it would be nice to have a plug-in specifically for this type of analysis, correcting for the foreshortening of the features closer to the edge of the disk, but given that all of the images suffer from this same 'aberration' then maybe it isn't too important anyhow.
Here's an example of one of Mark's images with the threshold gate applied. The plage regions are shown in green. Basically Image J returns the percentage of pixels in green over the whole image (including the black background). Setting the lower threshold to exclude the black background now turns the black to blue and Image J returns the percentage of the image pixels that are below this threshold. A simple calculation allows the green pixel population to be obtained from the entire population of pixels on the disk, excluding the background.
This is the resulting plot over time from 2010 until the present
which is in pretty good agreement with the predictions for cycle 24 shown below (red line):
and the official sunspot counts for cycle 24:
Here are some of Mark's images from various periods over this cycle.
2010 2014 2015
2016 and 2018 It will be interesting to continue this type of analysis during cycle 25 to mark its progress over the coming years.
Thanks for looking.
Thanks, Mark.
2010 2014 2015
Thanks for looking.
Re: Plage Progression Through Cycle 24
Thanks, Stue and Mark
Really titanic work!
- Has thanked: 141 times
- Been thanked: 240 times
That is an amazing and heavy lift. Well done sir.
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
- Has thanked: 20442 times
- Been thanked: 10248 times
That's way cool Stu! Like the method too!
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4787 times
- Been thanked: 4340 times
Awesome work and analysis of the images Stu...very impressive
- Has thanked: 17672 times
- Been thanked: 8793 times
That sure is a good project, fantastic results too, well done to you both a very enjoyable read.
Many thanks, everyone. We can look at building up a similar database during cycle 25. It will take a while
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Impressive work Stu, well done
Pedro Re'
- Has thanked: 9145 times
- Been thanked: 6026 times
A very interesting and well thought out analysis. Thank you both, Stu and Mark.
- Been thanked: 4904 times
Stu:
A fantastic and superb work done.
Best regards and thanks for sharing it.
- banjo
- Has thanked: 2090 times
- Been thanked: 2859 times
Superb work and analyse Stu.
paul
paul
sorry for my English translators google
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Fantastic work, Stu, much interesting indeed.
