Today's SUN (20200322) | TEC140 Ca-K polar faculae
- pedro
- Has thanked: 14 times
- Been thanked: 6578 times
WEB LINK:
http://pedroreastrophotography.com/sun_ ... 20-03.html
Inspired by Alexandra's fantastic work, I also imaged a few Ca-K polar faculae this morning with the TEC140 (Good seeing)
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
SUN (20200322) CaK (10:30 UTC). TEC140 F/7, LUNT152 CaK Module, PGR GRASSHOPPER 3 GS3-U3-28S4M, two-pane mosaic
SUN (20200322) H-alpha DISK & PROMS (09:00 UTC). LUNT60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20200322) H-alpha DISK & PROMS (10:00 UTC). TV101 F/5.4, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20200322) CaK PROMS (10:00 UTC). TV101 F/5.4, LUNT 1200 CaK Module, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20200322) WL, CaK & H-alpha (10:00 UTC). TV101 F/5.4, LUNT 1200 CaK Module, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
WEB LINK:
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
Pedro Re'
- Been thanked: 10248 times
Re: Today's SUN (20200322) | TEC140 Ca-K polar faculae
A great collection from today Pedro!
- Has thanked: 9417 times
- Been thanked: 5583 times
Hi Pedro,
Good images in H-alpha en CaK
Well done
Rainer
Well done
Rainer
- pedro
Thanks guys
Pedro Re'
- JochenM
- Been thanked: 1619 times
I love me some CaK and these look excellent Pedro!
- Has thanked: 17581 times
- Been thanked: 16697 times
The polar faculae seem difficult to see visually.
- Has thanked: 173 times
- Been thanked: 615 times
Pedro,
Thanks for that mate, greatly appreciated.
You've brightened up my otherwise drab and drismal ( from my daughter- Dismal + drizzle) day.
Deepsolar64,
Any CaK detail is extremely difficult to see (some say impossible - if you're over 14 years of age...)
Deepsolar64,
Merlin, can they be seen in white light?
The faculae recorded in CaK wavelengths is similar but not identical to that seen in the white light Photosphere.
- Been thanked: 8793 times
Well done Pedro!! plenty of time for some in depth studies I think these are super shots, I took some yesterday but I expect it will take me all day to process them
Deepsolar, yes of course you will be able to see them in White light, this is where they were discovered and named. However you will need very good seeing for contrast and a scope above 100mm aperture. A continuum filter will also help, or even better a blue filter (Wratten 47). See here a link where you can download a guide to what you could see when you set up (choose flattened intensity and pick closest image to your time now) http://jsoc.stanford.edu/HMI/hmiimage.html
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Fine images, Pedro, very crisp.
Visually polar faculae are better seen through a Herschel wedge and deep yellow or green filter.
Raf
- Been thanked: 4340 times
Excellent images Pedro
i am impressed by the lack of cable around your mount...I only see the USB cable to the camera.
My mounts/piers are a maze of wires and cables no matter how I try to de-clutter I spent the weekend moving computers and re-wiring everything after installing the EM400 and moving the solar equipment to the big roll-off and installing the MI-250 in the dome. I think everything is working now, save the SSM which isn't powering up when its plugged into the USB...need to play around with it some more.
- pedro
Thanks guys
Ken: Check out this video with more Ca-K images
PEDRO RE' | SOLAR ASTROPHOTOGRAPHY
HR SUNSPOTS CaK
LUNT152, TV101, IKHARUS80, PST CaK
GS3-U3-28S5M-C GS3-U3-28S4M-C
(2013/2017)
http://re.apaaweb.com
Brian: Some mounts have a large conduit to run additional cables through (e.g. Paramount). This is not the case with Takahashi mounts. I tend to use only the control box to image the sun (EM400). It's simple and efficient. Sometimes I also plug the SSM as well
HR SUNSPOTS CaK
(2013/2017)
Pedro Re'
- Been thanked: 4904 times
Pedro:
Beautiful shots and equipment.
Fuerte abrazo,
Fuerte abrazo,
- pedro
Gracias Eric
Fuerte abrazo
Be healthy, be safe, be well
Fuerte abrazo
Pedro Re'
AlexandraDeepsolar, yes of course you will be able to see them in White light, this is where they were discovered and named. However you will need very good seeing for contrast and a scope above 100mm aperture. A continuum filter will also help, or even better a blue filter (Wratten 47). See here a link where you can download a guide to what you could see when you set up (choose flattened intensity and pick closest image to your time now) http://jsoc.stanford.edu/HMI/hmiimage.html
I do have a Celestron 102mm refractor I just need to outfit it for solar use, either with solar film or better yet, a wedge. My usual white light instrument is smaller, a 70mm Orion refractor with a glass filter. I do have a Baader continuum filter.
P.S. And Pedro, that is an awesome YouTube movie. I love Cak but probably could not see it visually. I hear CaH is a bit easier to see.
- Has thanked: 8418 times
- Been thanked: 8165 times
Very nice images, Pedro.
- pedro
Thanks Stu
Under isolation I image the sun daily
Pedro Re'
You've found something positive in such a negative situation!!
- pedro
Yes I did
Have to keep ourselves occupied
Pedro Re'
I very much agree Pedro. Stay occupied and stay positive! And may your skies stay clear and sunny.
- pedro
Montana wrote: ↑Mon Mar 23, 2020 9:14 am Well done Pedro!! plenty of time for some in depth studies I think these are super shots, I took some yesterday but I expect it will take me all day to process them
I have seen them a small number of times now using my C102 with the wedge but today I actually picked them up in my 70mm refractor which uses an almost white ( tinge of green ) glass filter. Seeing was excellent. I was really surprised at doing this. I picked up several faculae in the north and while they weren't exactly obvious they were certainly more than hinted at. My old eyes must still work pretty well.
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Excellent shots, Pedro!! Always feel great to see your equipment and tri-band images!!
Alfred
Alfred
