Sol from the 2nd of June 2020.
- Been thanked: 4971 times
Hi:
Some shots from today, used the 3 scopes at the home observatory.
Thanks for looking, I just had a gap to take the shots, it clouded all over.
I usually take 600 SER frames, but the last shot was from 1600 frames.
Re: Sol from the 2nd of June 2020.
Hi again Eric.
Some well nice and crisp images there. The large prom certainly shows much detail.
Best Wishes
Best Wishes
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Has thanked: 17845 times
- Been thanked: 16981 times
I remember the bright end of the big prom. Your images show it in crystal-clear detail!
- JochenM
- Been thanked: 1619 times
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Awesome images Eric. Apologies you have undoubtedly been asked this many times, what is the "Ca-K PST Mod" you refer to in your Ca-K image names?
David
- Has thanked: 20783 times
- Been thanked: 10471 times
Great shots Eric, i'm guessing the haze rolled in towards the end of the session looking at your graph.
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Terry, Dan, James, Jochen, David, Mark and Alfred, much appreciated feedback.
David, the CaK modification was made from an old CaK PST that I had, so I took the parts out and machined an adapter to put the filter inside. I use either a Baader K Line or the Venus filter at the camera nose. (see photo)
Mark, no it was hazy since started, when the sky is clear the input is set at 0.8, so haze and clouds show the lower input quite well.
Hope you all are well, so lets keep safe.
- Been thanked: 2725 times
Hello Eric,
Excellent images !!
Excellent images !!
Always great images Eric and these are no exception. Super prom detail!
Phil
Phil
- Has thanked: 8544 times
- Been thanked: 8282 times
Fantastic images, Eric. Lovely FDs and proms.
- Been thanked: 8905 times
