June 11, 2020 AR12765 using Questar/Quark + June 12
Hi All,
Another clear morning, what a nice surprise. Today I took the little Questar out from the shadows, where it has been hiding for many months, and showed it the sun. Attached to the axial port was a 2.5x Powermate followed by the Quark Combo a .5x focal reducer and PGR camera. A Baader DERF was mounted on the front.
With only one main target, AR12765, and with no clouds it did not take very long to capture all the videos I needed. I had seen Questar imagers using the built in diagonal and eyepiece port on the scope to image so I thought I'd give it a try. It seemed a bit unwieldy to stick the Powermate, Quark, and camera into the eyepiece port. I can see how image orientation can get a little confusing.
The first image is the normal axial setup. The rest of the images were taken from the eyepiece port without proper orientation unfortunately.
Re: June 11, 2020 AR12765 using Questar/Quark
Whichever way round Phil, these images are well good and AR2765 certainly shows all.
- Has thanked: 9401 times
- Been thanked: 5565 times
Very good
- Has thanked: 9144 times
- Been thanked: 6025 times
- Been thanked: 4904 times
Phil:
Very nice session, at my place it clouded all day.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
I like the mono best, great images.
Dan
South central Indiana
USA
USA
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Hi Phil,
The details are incredible coming from a small scope. It is fits its reputation in the hands of an expert.
Would be nice to see a photo of your setup with the Questar.
Alfred
Alfred
- Has thanked: 141 times
- Been thanked: 240 times
Yikes those are pretty
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
- Has thanked: 17572 times
- Been thanked: 16693 times
Phil,
Your images show incredible depth as well as sharpness! And what type/brand of mount is your setup mounted on?
- Has thanked: 17667 times
- Been thanked: 8788 times
Wow!! your images are always flawless you have an excellent Quark too
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Very nice images.
Marios S.Ioannou
Sketcher/Visual Observer
Excellent seies, Phil! And a very nice Questar setup.
Thanks for sharing.
Thanks for sharing.
Nice set-up there Phil and well done on the fab imaging
Re: June 11, 2020 AR12765 using Questar/Quark + June 12
Another day with the Questar/Quark Combo setup. This time I tried three different scales using the .5x focal reducer with an additional 5mm spacer attached. This produced the maximum field of view with all four corners being cut off. I had to reduce the ROI to avoid vignetting. The first image is with the reducer plus the spacer, next is with the spacer removed and lastly with no focal reducer. Two inverted images are included to show a nearby prom.
- Has thanked: 8415 times
- Been thanked: 8161 times
Fabulous images, Phil. That’s a heck of a setup, producing wonderful images.
Wow! the last image looks like a rearing horse!
