June 7th Session
Has thanked: 64 times
Been thanked: 4406 times
June 7th Session
Post by MapleRidge »
Good day everyone...
Finally a sunny Sunday that I didn't have to work, so I got to spend some time at the scope :) The bonus was the new activity that graced the disk and made a worthy target to image and experiment on! I would like to spend more time processing these, but time is scarce so I'm posting what I have managed to do so far.
The seeing was average as I began, but slowly deteriorated as the fields adjacent to the observatory heated in the sun, but the crops are now growing well and the daytime heating should moderate in the coming weeks.The first images are the full disk shots, starting with the Ha through the LS80T/DSII/B1800Ha and the ZWO174mm camera:
The next two are through the i-Star 150mm, f8 scope using a Lunt solar wedge/Baader Continuum filter for WL and a modified Lunt solar wedge/B1800CaK/Baader K-Line filer set for the CaK disk:
The next series of images are CaK through the same filter sets as the full disk, but with a 3x tele-extender ahead of the camera to boost the resolution on the first image and a 2x for the second two shots:
The image below was through the modded CR-150/DSII/B1800Ha scope, with the pressure in the DSII etalon set to 0 PSI for the deep red continuum image:
The pressure was then adjusted to 15PSI to get the Ha detail in AR2765:
I had time to setup the on-going PST mod trial on the C9.25 Edge, but since this was tried near the end of the session in the poorer seeing the results were not the best...still a work in progress:
I apologize for the image quality on some of the posts...hope to be able to have more time soon!
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Re: June 7th Session
Post by JochenM »
Good to hear that you managed to get another session in, Brian. Excellent results as well.
How do you check/control the pressure in the tuner btw? You have the Lunt USB control unit or you built something yourself?
Jochen Maes
Belgium
https://www.jochenmaes.com
Has thanked: 17807 times
Been thanked: 16940 times
Post by DeepSolar64 »
You got those little extensions on the spot's umbra. I picked those up visually in my C102 with the Altair Herschel Wedge.
Has thanked: 17888 times
Been thanked: 8887 times
Fabulous Brian, glad you have finally managed a break to have a good time in the sunshine. An excellent set all round :bow :hamster:
Out of interest how tall is your sweetcorn now? ours are still only 12 inches tall in the fields but I remember ours were at least a month ahead of yours at the beginning. I am wondering if yours are catching up and overtaking.
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
Excellent work Brian.
Marios S.Ioannou
Sketcher/Visual Observer
My thanks to everyone for your comments and feedback...always appreciated :bow
Alexandra, our corn is coming nicely but I wouldn't put any at a foot high yet. If we get another round of hot weather it will jump to be knee high in a week or so.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Hi Brian,
My fav image of yours is the multiple Sun-spot collection. So clear and explains what AR2765 was all about.
Thanks
John
Has thanked: 1313 times
Been thanked: 64 times
Post by John »
Lovely set of images. I would be interested to know the make of tele-extenders that you used for the CaK images.
John
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
Hey Brian: these are truly excellent. I can tell you had the time and peace to shoot a nice session.
Franco :bow :bow
Has thanked: 8523 times
Been thanked: 8251 times
Post by Carbon60 »
You've had a busy session, Brian, with excellent results.
Very nice.
Terry, John, Franco, and Stu...
Thanks for your feedback on the images :bow
John, I have a set of Explore Scientific extenders...2x and 3x in both 1.25" and 2". The 1.25" versions were used on these images. The Ha was actually imaged through a 2.7x tele-centric from Airy Labs, but I forgot and put the wrong amplification factor in the description. I haven't tried it in CaK or WL yet...it's all threaded fittings at both ends and doesn't interface with the Lunt wedges very easily. Might make it work with a few SCT and T-thread adapter rings...a project for the end of 16hr work days :lol:
yltansg
Has thanked: 1454 times
Been thanked: 1444 times
Post by yltansg »
Hi Brian,
Great shots of FDs and close-ups in both HA and CAK.
Good to hear that the sweet corn are growing well.
Alfred
Thanks Alfred!!!
Jochen...
Sorry, I missed your question about the pressure adjustments and yes, I am using the Lunt USB Remote Tuner.
eroel
Been thanked: 4957 times
Post by eroel »
Brian:
A really beautiful session, super images.
Keep well my friend.
Thanks Eric :bow
Best wishes for you and your family to stay safe as well.
