12th June 2020 Some more images from today's success - at last.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
OK Folks,
Now I have lost the "pesky rings" I have been playing with the few AVI's taken this morning, with the attached results.
Enjoy
Capture 2020-06-13T12_57_42_AS_p100_g2_ap5_conv.jpg (13.47 KiB) Viewed 579 times
Capture 2020-06-13T12_50_55_AS_p100_g2_ap1_conv.jpg (48.72 KiB) Viewed 579 times
Capture 2020-06-13T12_46_22_AS_p100_g2_ap1_conv.jpg-2.jpg (44.42 KiB) Viewed 579 times
Capture 2020-06-13T12_46_22_AS_p100_g2_ap1_conv.jpg (105.25 KiB) Viewed 579 times
Capture 2020-06-13T12_45_56_AS_p100_g2_ap10_conv.jpg (13.38 KiB) Viewed 579 times
Capture 2020-06-13T12_40_59_AS_p100_g2_ap4_conv.jpg (3.62 KiB) Viewed 579 times
AR2765 13-6-2020 Cal-K false colour.jpg (84.33 KiB) Viewed 579 times
AR2765 - Capture 2020-06-13T12_13.jpg (290.63 KiB) Viewed 579 times
EGRAY_OBSERVATORY
Re: 12th June 2020 Some more images from today's success - at last.
The heading should have read the 13th June 2020 (Saturday)
eroel
Been thanked: 4957 times
Post by eroel »
Terry:
Nice results and no rings and yes, the images are from the 13th of June.
Has thanked: 17807 times
Been thanked: 16944 times
Post by DeepSolar64 »
These are some of the best images you have done, Terry!
yltansg
Has thanked: 1455 times
Been thanked: 1444 times
Post by yltansg »
Hi Terry,
Congrats on getting rid of the NR. How did you do it?
Alfred
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Looking good, Terry.
Jochen Maes
Belgium
https://www.jochenmaes.com
Derek Klepp
Been thanked: 171 times
Post by Derek Klepp »
Good results keep at it. It takes a while to work out what works with your setup and the local seeing conditions.
Derek
EGRAY_OBSERVATORY
Many thanks Eric, DeepSolar64, Alfred and Derek.
Alfred, Substitution was the method. Whilst try to sleep the night before, I came-up with the thought about simply swapping the two (identical)- cameras between the Ha and Cal-K scopes. So thankfully the weather changed from the forecast on Saturday morning and gave me the time I needed to try that out. Immediately the rings were sent to the bin !!!
Why those two cameras should be different, is still unknown as were sourced together from the same supplier, but presumably as different lines of light and intensity between Ha and Cal-K - is possibly why.
Within the last quiet year, it is possible that some changes were made and the cameras may have been swapped from the previous Solar-imaging sessions - where that NR problem didn't show up then.
So now I can get on with the task in hand and also to try some Telextenders etc., to improve the imaging too.
Just now the PC is playing-up with some definite hardware problems, so I am hoping to find another suitable PC for the purpose.
Best wishes
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
Beautiful!
Marios S.Ioannou
Sketcher/Visual Observer
EGRAY_OBSERVATORY
Thank you Mario
