The Sun - 14th June 2020
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Early session today as the sky was cloudless when I got up. Lots to do / see with the AR still visible in both WL and Ca-K as well as some faint proms.
Start off with the Ca-K full disk. the usual 6 panes to cature, stitched in MS ICE.
Then the proms. Tricky today, very faint and even with the ASI in 2x2 bin mode these were difficult to grab and even tougher to process. So a bit noisy in some cases, I may have another go at processing them later.
Close up with the AR in Ca-K and then white light
Continuing the white light theme I picked up some nice granulation
And finally, just as the clouds started moving in I switched to the Bresser for a white light full disk. A bit soft this one but it was a bit of a rush job tbh.
Last edited by David_The_Bears_Fan on Sun Jun 14, 2020 7:41 pm, edited 1 time in total.
David
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Re: The Sun - 14th June 2020
Wonderful images
Marios S.Ioannou
Sketcher/Visual Observer
- JochenM
- Been thanked: 1619 times
- Has thanked: 17581 times
- Been thanked: 16697 times
David,
Very nice images! I love the first full-disc CaK image and also really like like the two white light granulation images. The colored one shows them a bit better though.
- Has thanked: 9145 times
- Been thanked: 6026 times
- Has thanked: 8418 times
- Been thanked: 8165 times
A fine set of images, David. Nicely done.
- Been thanked: 171 times
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Very nice David. What Equipment did you use for the granulation images?
Dan
South central Indiana
USA
USA
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Nice collection of images, David. The CAK FD and close-up images turned out very well.
Alfred
Alfred
- Been thanked: 4904 times
Thanks all
Dan, Evostar 120 achro, Lacerta Herchell wedge, Revelation 2.5x barlow, Solar Continuum, UV/IR cut and ASI178MM. 55 frames stacked from 1000 captured.
David
- dhkaiser
[/quote]
[/quote]
David I curious are your filters before or after your wedge. I have a wedge and filters on order.
[/quote]
Dan
USA
USA
[/quote]
[/quote]
After the wedge Dan. I have a 2" UV/IR cut filter so I could put that in front of the wedge I suppose. Not sure what I would gain or if I would melt / damage the UV/IR filter? At the moment I have 1.25" continuum and UV/IR cut filters stacked on top of the Lacerta ND3 inside a T2 extension below my eyepiece holder. I kept forgetting to use the UV/IR when imaging so now I don't have to remember, it's always in there ready and has no detrimental affect when used visually.
What wedge / filters did you go for?
David
- dhkaiser
[/quote]
[/quote]
David I ordered the Lunt wedge and the Continuum, UV/IR from High Point, all 1 1/4. Will be using them on a Lunt ED 102 mm.
[/quote]
Dan
USA
USA
[/quote]
[/quote]
Nice, you should get some great views / images with that setup. Just reading your other thread on this. I see others use their UV/IR in front of the wedge so will give it a go if the sun shows up today.
David
- Been thanked: 10248 times
A very nice set David!
