Full disk 16-06-2020
- Has thanked: 9413 times
- Been thanked: 5577 times
Sunny as usual and here today's Blank Sun disk except of some filaments and a filaprom near the disappeared AR 2765 area.
Hopefully the bright spot seen in the Heliographic image of today appears tomorrow at the Northeastern limb at about +20°
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Been thanked: 10246 times
Re: Full disk 16-06-2020
Excellent disks Rainer!
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Good disks Rainer, thanks.
David
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Hi Rainer,
The filaprom looks great on the solar disk. I have always wanted to ask you, what are those slightly darker lanes on the first image? Are they caused by clouds?
Alfred
Alfred
Alfred
Alfred
- Been thanked: 4340 times
Fabulous full disk images Rainer...the fila-prom really stands out
- Been thanked: 16694 times
Very nice images Rainer. Clouds here have prevented me from getting a decent view. That filaprom looks great! It looks like we have a blank WL sun again. Minimum isn't over yet.
- Been thanked: 171 times
- JochenM
- Been thanked: 1619 times
Hi Alfred,
That is the difference between the Hot Spot area and the corners. BTW my H-alpha disks are always a mosaic of 9 images. That is why they have this pattern. Do you look at my images at full size ? Open the image in a new tab and when the mouse shows a loupe with a plus sign click on the image. My Sun disks are approximately 1870 pixels in diameter.what are those slightly darker lanes on the first image ?
While the darker areas oscillate around 190 the brighter areas oscillate around 210. So there is a color value difference of about 20. This measured in 8 bit colour depth. Perhaps it could be killed using a flat but that is too much work for me. I am lazy by nature
Looking at it as an Icon the dark lanes are more visible then at 100% size.
- Been thanked: 8791 times
Absolutely lovely Rainer, definitely best at full res I love the filaprom!
- yltansg
Hi Alfred,
[/quote]
Thanks Rainer for the explanation. Yes, flats should resolve that. They are lovely in full resolution too!!
Alfred
- Been thanked: 4904 times
