Hi all,
To recap, the best C11 CAK image was obtained using a TV x2.5 powermate + CAK PST yellow filter. Unfortunately it has a reflected light:
Following up on the suggestions from friends I have tested several ways of placing the powermate and tilt adjusters. Unfortunately they all didn't work.
The last configuration that I will be testing is to place the TV PM nearest to the output of the C11:
Unfortunately I found out that my TV x2.5 PM was the older version. The newer version TV x2.5 powermate has arrived:
Unfortunately the weather is not cooperating. While waiting for good weather I am thinking of removing both the 2 ERFs in the nosepiece of the LUNT CAK module. I am assuming that the 2 glass pieces are the 2 ERFs. So far I have removed the one furthest away from the diagonal.
The purpose of removing both ERFs in the LUNT CAK Module is to have more light reaching the camera, assuming that the D-ERF has provided sufficient protection. With this mod, I should be able to set the exposure to less than 5msec to freeze the seeing.
My question is: Should I remove both ERFs in the nosepiece?
Alfred
Getting rid reflected light in C11 CAK imaging
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
- Has thanked: 1171 times
- Been thanked: 1360 times
Re: Getting rid reflected in C11 CAK imaging
Alfred,
Is your primary D-ERF tilted at all? If not, I would add a small 1 degree tilt to it via rubber gasket under 1/2 of the filter inside the holding cell. It should handle your reflection.
I too am curious about the innards of a Lunt module in terms of what is in front of the actual narrowband filter in case I disassemble mine to add a 2nd filter for a double-stack.
- yltansg
Hi Marty,MalVeauX wrote: ↑Sat Jun 20, 2020 1:32 pm Alfred,
I will try tilting the D-ERF as suggested to see its effect.
This is how the 2 filters look like:
Are these 2 filters the 2 ERFs and I can remove them totally since I have an ARIES D-ERF?
Or is one of them a CAK filter that I need to retain? One of them looks "yellowish" under white light.
Alfred
Alfred,yltansg wrote: ↑Sat Jun 20, 2020 10:50 pmHi Marty,MalVeauX wrote: ↑Sat Jun 20, 2020 1:32 pm Alfred,
Alfred
I believe that these two filters work also as wide CaK filter(s).
Valery.
- yltansg
Thanks for your feedback. One of them has a yellowish tint:
While the other doesn't:
As I am doing purely imaging and have the ARIES D-ERF, I will try imaging with the LUNT CAK diagonal (minus these 2 filters) and a yellow PST CAK filter and see its performance. Later I will put in the filter with yellowish tint and find out how it perform with the PST CAK filter.
Alfred
- Has thanked: 20424 times
- Been thanked: 10243 times
Re: Getting rid reflected light in C11 CAK imaging
You will need one of them Alfred, the goldish one, it's that colour to reflect the blue light. The all important CaK filter is the 12mm one in the nosepeice. It may well be that you need both of the larger filters in depending how wide the passband is of Valerys DERF.
The front two filters are just sub aperture ERFs. There will be 2 to increase the out of band blocking.
You would do well to have a good search in the mods section, myself and Swisswalter did all this years ago, so the information already is out there. Walter scanned the transmission of the filters etc.
- Has thanked: 17655 times
- Been thanked: 8787 times
The reflection is not from the front ERF (Aries), I still get the reflection in white light when using Baader Solar film!
- yltansg
Thanks Alexandra for that piece of information. It rained for extended period this weekend. Hope to test this configuration:
Even if this fails, I still can use the 2" TV x2 PM
Waiting for clear skies.
Alfred
- yltansg
Thanks Mark for the very useful information in the Mods section. I will look it up.marktownley wrote: ↑Sun Jun 21, 2020 9:15 am You will need one of them Alfred, the goldish one, it's that colour to reflect the blue light. The all important CaK filter is the 12mm one in the nosepeice. It may well be that you need both of the larger filters in depending how wide the passband is of Valerys DERF.
Alfred
- JochenM
- Been thanked: 1619 times
Very interesting information. Good luck with the tests, Alfred (will keep an eye out for the results).
