July 25: AR12767 in CaII K
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Hello Everyone.
Here are some shots of the AR at two image scales taken in CaK. Seeing was not really good enough to support the higher magnification image and I am really pushing (beyond) the instrument limits by imaging at f63. To me, there really seems to be no additional detail visible in the higher versus lower magnification image.
The equipment used (based on a Stellarvue SV115 refractor) is marked on the photos.
Peter
Peter
- Has thanked: 9723 times
- Been thanked: 5773 times
Re: July 25: AR12767 in CaII K
Hi Peter,
Great images
Great images
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Well done Peter on two superb CaK images, quite stunning..
Thanks
Thanks
- Has thanked: 17853 times
- Been thanked: 16996 times
The plage activity around the spot shows up really well.
- JochenM
- Been thanked: 1619 times
Very nicely captured and processed, Peter.
Just out of curiousity; what did you use to push it all the way to f63?
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Great shots, fine details inside the penumbra
Raf
- p_zetner
Thanks for your kind comments everyone!
I reprocessed these shots (different video chosen for the high magnification image) with a bit of a lighter touch.
Hope you enjoy and I'd be interested to know if you have any thoughts on the new processing vs the old.
Peter
Peter
- Been thanked: 4980 times
Peter:
Super clean and clear CaK images, nicely processed.
Good Sunday to you and all.
- Has thanked: 8559 times
- Been thanked: 8290 times
Really great images, Peter. I must admit to liking the second set better than the first.
- Been thanked: 10489 times
Nice images Peter, I prefer the softer processing of the second set.
I like the second compared to the first because I think the contrast is much better, giving better definition of the spot details and the plage isn't blown out
Nice set of images! I second Mark and Alexandra!
And I'd also like to ask what Barlow you used to reach f/63? (Seems to work fine for CaK. FFC?)
Frank
Frank
- p_zetner
Thanks for the comments, everyone.
I have a tendency to get too heavy handed with the processing and then, after posting, I realize I've gone too far! I tried to rein my impulses on the second set of images.
Frank: I use a homemade barlow consisting of 5 or 4 achromatic doublets depending on whether I'm interested in 9X (f/63) or 5.7X (f/40) magnification. There are either 3 or 2 negative achromats of -120mmfl in a negative lens group followed by the filters then a -150mmfl and +160mmfl pair to comprise a positive lens group. The -120mm lenses came from Surplus Shed and the others came from Edmund Optics. For the positive lens group, I've also used a pairing of -120mmfl and 120mmfl lenses, from Surplus Shed, for a somewhat lower magnification. I can give you more details if you'd like.
All the best.
Peter
All the best.
Peter
- Has thanked: 1188 times
- Been thanked: 1382 times
