Almost full disk WL July 28, 2020
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Here is my first effort from this morning, have not looked at the other files. As you can see I am unable to get the FD with my Lunt 102 and ASI 178. Any suggestions on a focal reducer that would mount on this system?
Dan
South central Indiana
USA
USA
- dhkaiser
Re: Almost full disk WL July 28, 2020
And the new AR
And the new AR...
And the new AR...
Dan
USA
USA
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Nice shots, very crisp.
To bring the solar disc within the small sensor of my CCD I make use of that small reducers that have the same thread of eyepiece filters, just put them on the camera nose. They came basically in two versions both labeled as 0.5x, this the weaker and this is the stronger The actual reducing factor depends on the distance from the sensor, therefore I purchased a set of C-spacers in order to change the reducing factor based on the focal length of the scope Reducing the effective f.l. requires refocusing inward therefore there shall be enough backfocus that can be eat by the reducer.
Hope it helps
Hope it helps
Raf
- Has thanked: 9417 times
- Been thanked: 5583 times
Hi Dan,
Why not make a 2 image Mosaic ? That is easy with white light and you do not loose resolution.
- dhkaiser
Thanks Raf. I'll look into that.
Dan
USA
USA
- dhkaiser
[/quote]
Hi Dan,
[/quote]
Something to consider, what software?
Hi Dan,
[/quote]
Dan
USA
USA
Hi Dan,
Any image processing software. What software packages do you have ?
You can even manually join them to a full disc. There is no big science behind that.
I use Photoshop 2020, I know it sounds expensive, but I have it since more then 20 years and now I have a monthly subscription for US $ 9.95 per month.
In Photoshop you just paste the second image over the first. There is a function " Difference " for overlaying and so you see where the overlaid image fits on the lower one and if there is a function Blend Layers you got it.
- dhkaiser
Thanks Rainer, I use Photoshop Elements, I'll look into that.
Dan
USA
USA
- Has thanked: 8418 times
- Been thanked: 8165 times
Excellent WL images, Dan.
Microsoft’s ICE image stitching software works well.... and it’s free.
- Been thanked: 10248 times
Nice images Dan. I'd recommend the mosaic over a reducer. Use ICE like Stu suggests if there's not something in elements that does it.
- dhkaiser
Thank you Stu and Mark. Elements does have a merge option however it seems not to work on my solar images. I will look at Microsoft’s ICE image stitching software. Thanks again.
Dan
USA
USA
- robert
- Has thanked: 4 times
- Been thanked: 1274 times
Hi Dan
I use a focal reducer which has C mount which gets it closer to the chip. I forget where it came from but I attach a photo. It works exactly for my CCD (PGR Ch3) with an ED80 for FD in WL and CaK. I prefer the loss of detail to the very faint slight edges you get usually using mosaics. It is less effort too. I have used Microsoft ICE and it is extremely good too.
Good luck
Robert
Good luck
Robert
- dhkaiser
Thanks Robert. I have ordered a .5 reducer and downloaded ICE. Will experiment with both.
Dan
USA
USA
- Been thanked: 8794 times
Some lovely WL images Dan, I like the shot of the new AR
- JochenM
- Been thanked: 1619 times
Looks good, Dan.
Regarding the mosaic; all of the suggested solutions should work fine (ICE, merge function in PS/Elements,...). Just make sure you have enough overlap in your separate images. Judging by your fov; I would opt for 3 panels (top to bottom) to play it safe.
- Has thanked: 9145 times
- Been thanked: 6027 times
Very nice images, Dan. The new AR came out really well.
- Been thanked: 4904 times
Dan:
Very nice images.
As for getting the FD on the chip, first I use a chuck connected to the 0.5X reducer so to find the proper distance to the chip of the camera, so by moving the extension in steps in the chuck, you can get the diameter of the solar disc you need, by just looking at the PC monitor.
After I find the proper distance, then I make an extension of the proper length and leave it on the camera.
The photo shows the chuck and the extension in my ZWO camera.
Very nice images.
- dhkaiser
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Hi Dan,
Great catch on new AR. Wish you all the best to get that FD.
Alfred
Alfred
