Sun part 2 Friday 31st July WL & CaK
- Has thanked: 18105 times
- Been thanked: 8942 times
I have now processed my WL and CaK both taken with TEC140 (with CaK stopped to 100mm). Camera ASI174 and 5x powermate for the close ups. They do look best if clicked through to Flickr and click the magnifier. I actually managed to spot the large prom in CaK first which was a surprise, I could see a large rectangular pixel of paler light in the camera (my superb new computer monitor). After processing I could see it as a prom. On my new monitor I have huge concentric rings of grey in this image but on my computer here at work it looks mostly fine, so hopefully you see this version and not huge blocks of grey. It does make solar processing a shot in the dark (and capture!).
Sun_073514_31_07_2020_combined by Alexandra Hart, on Flickr
2020-07-31 CaK Full disc a by Alexandra Hart, on Flickr
2020-07-31 CaK Full disc b by Alexandra Hart, on Flickr
Sun_072500_31_07_2020 by Alexandra Hart, on Flickr
Sun_072902_31_07_2020 by Alexandra Hart, on Flickr
2020-07-31 WL full disc by Alexandra Hart, on Flickr
Sun_074507_31_07_2020 by Alexandra Hart, on Flickr
Sun_074803_31_07_2020 by Alexandra Hart, on Flickr
and I am very happy to say that thanks to Alfred I think the TeleVue 2.5x Powermate is solved. I unscrewed the black part off my Celestron 2x Barlow and sellotaped it to the top of the Powermate (about 4cm extra size) and tried it on the C11 + CaK wedge - no central spot. The seeing was hideous so I couldn't make out features or clarity but the reflection seems to be gone. Thanks Alfred I need a permanent fix now.
- Has thanked: 20962 times
- Been thanked: 10591 times
Re: Sun part 2 Friday 31st July WL & CaK
Lovely images, ooodles of detail in the CaK closeups.
Have you tried different display settings with your new monitor? The posterisation sounds like it's running on fewer bits than it should be... Do you have a new PC and running a secondary 4k monitor?
- Has thanked: 9387 times
- Been thanked: 6201 times
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Excellent details there Alexandra!
Dan
South central Indiana
USA
USA
- Been thanked: 1390 times
Thanks everyone
Mark, it is a Dell Precision 17 inch laptop with 4 K screen. It cannot display black at all even in video or photograph, it condenses it to solid blocks of greys. In full colour it is wonderful, for black it is hideous. I see no way round the problem. Trying to capture a prominence is like looking at one straight block of featureless grey.
Have you tried running the display in FHD (1920x1200) opposed to UHD (4K)?Montana wrote: ↑Mon Aug 03, 2020 5:45 pm Mark, it is a Dell Precision 17 inch laptop with 4 K screen. It cannot display black at all even in video or photograph, it condenses it to solid blocks of greys. In full colour it is wonderful, for black it is hideous. I see no way round the problem. Trying to capture a prominence is like looking at one straight block of featureless grey.
- Has thanked: 65 times
- Been thanked: 4460 times
Your follow-up series of images are great Alexandra
Glad to hear your reflection was solved as well...now just need some good seeing
- Has thanked: 8588 times
- Been thanked: 8324 times
Lovely images, Alexandra. Nice details and wonderful capture of that huge prom in CaK.
As Mark suggests, there be an optimal configuration setting for your monitor. It’ll probably be trying to display millions of shades of grey when there are fewer available depending on the bit depth. There will be a suitable adjustment to the number of displayed ‘colours’ under settings.
Thanks guys
Mark, we tried that last night and it made it 10x worse we will have to see if the Xrite i1Pro helps matters at all (they just need to send it, still waiting).
- Been thanked: 171 times
- JochenM
- Been thanked: 1619 times
- yltansg
- Has thanked: 1460 times
- Been thanked: 1447 times
All your images are great. I especially like the CAK close-ups, its fluffy texture.Montana wrote: ↑Mon Aug 03, 2020 7:39 am On my new monitor I have huge concentric rings of grey in this image but on my computer here at work it looks mostly fine, so hopefully you see this version and not huge blocks of grey.
Glad to hear that you have removed the reflected light spot on C11 image. I look forward to seeing great CAK shots with x2.5PM soon!!
Alfred
- Martin_S
- Has thanked: 999 times
- Been thanked: 3061 times
Great Cak Alexandra.
Martin
Martin
- Has thanked: 1283 times
- Been thanked: 1071 times
Wow, Alexandra, I didn't realized that 100mm in Ca outputs such details
Very impressed.
Leo
Very impressed.
Leo
100mm in Cak is equivalent resolution to 160mm in Ha.
Have you tried updating the drivers for the graphics card?
